Suspension & Brakes Theory, alignment, spring rates....
koni and omni
Old Nov 28, 2005 | 10:50 AM
Teglessb18's Avatar
Default koni and omni
Ok so I was thinking about getting some new suspension. Does anyone have Koni yellows with the omni power coil slips? Would this be a good setup. I dont have the money for the GC/Koni setup. Would it be better to get the omni full coilovers, GC/Tockico, or Omni coil slips and Koni Yellows? This is a daily driven car. I once saw a thread where some cheap coilovers broke or something on the yellows. Will this happen with the omnis?
Thanks
Old Nov 28, 2005 | 11:00 AM
Tyson's Avatar
Default Re: koni and omni (Teglessb18)
i dont believe omnipower adjustable spring kit, aka slipovers, will fit properly over koni's. youll need some adaptor to fit over the snap rings. you might want to double check with omni about that. you dont want to put them on over the separate lower perch that comes with konis, they just dont like that.
Old Nov 28, 2005 | 11:23 AM
Johnny Mac's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglessb18 &raquo;</TD></TR><TR><TD CLASS="quote">Ok so I was thinking about getting some new suspension. Does anyone have Koni yellows with the omni power coil slips? Would this be a good setup. I dont have the money for the GC/Koni setup. Would it be better to get the omni full coilovers, GC/Tockico, or Omni coil slips and Koni Yellows? This is a daily driven car. I once saw a thread where some cheap coilovers broke or something on the yellows. Will this happen with the omnis?
Thanks</TD></TR></TABLE>
Honestly, if I were you, I would save up for the Koni/GC combo. No sense in buying lower quality stuff and then having problems with it. The Koni/GC is a proven (many times over) combination that works very well. You might be able to find some other stuff like Skunk2 et. al that might work, but why take a chance?
Old Nov 28, 2005 | 05:42 PM
Teglessb18's Avatar
Default Re: koni and omni (Johnny Mac)
ya true. Would a tockico illumina with omni slips be a decent setup for daily driving?
Old Nov 28, 2005 | 06:27 PM
Teglessb18's Avatar
could some springs like h&r race go on konis without a problem?
Old Nov 28, 2005 | 06:57 PM
Johnny Mac's Avatar
You'll need to check fitment of different spring/coilover kits with the damper manufacturers you wish to use.
Old Nov 28, 2005 | 07:21 PM
t0ekn3e's Avatar
m friend has koni yellows nd h&r race springs on his gsr. i thnk it is great for daily driving.
Old Nov 28, 2005 | 07:25 PM
Teglessb18's Avatar
Default Re: (t0ekn3e)
awesome thanks guys
Old Nov 29, 2005 | 08:49 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglessb18 &raquo;</TD></TR><TR><TD CLASS="quote">ya true. Would a tockico illumina with omni slips be a decent setup for daily driving?</TD></TR></TABLE>
no, dont get omni adjustable spring kit. too stiff, and justa poor quality spring and a cheap sleeve and collar. not worth your money, and not going to get you want you want.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglessb18 &raquo;</TD></TR><TR><TD CLASS="quote">could some springs like h&r race go on konis without a problem?</TD></TR></TABLE>
definately, yes.
using a regular spring kit and good shocks like illuminas or konis will be your best bet.
Old Nov 29, 2005 | 08:56 PM
Teglessb18's Avatar
Default Re: koni and omni (Tyson)
well would a setup like tockico illuminas and some h&r race have better handling then say some omni coilover (the ones with just ride height ajustability) and which one would be more comfourtable (sp?) ride? my guess would have to be omni coilovers= better handling and tockico/h&r better ride is that right?
Old Nov 29, 2005 | 10:13 PM
Tyson's Avatar
i havent used omni crap. so i guess i cant comment on that.
Old Nov 30, 2005 | 07:52 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglessb18 &raquo;</TD></TR><TR><TD CLASS="quote">well would a setup like tockico illuminas and some h&r race have better handling then say some omni coilover</TD></TR></TABLE>
I would just stay away from the omni all together. They're very stiff and poor quality.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglessb18 &raquo;</TD></TR><TR><TD CLASS="quote">my guess would have to be omni coilovers= better handling and tockico/h&r better ride is that right?</TD></TR></TABLE>
I can't say about the handling, because stiffer is not always better; and the Tockicos may not even be able to dampen the spring properly. H&R will most likely give the better ride, but it's just a much better product.
I'd actually go with those and a set of Konis, and then you'd still have some ride height adjustability with the adjustable collar.
Old Nov 30, 2005 | 09:57 AM
Teglessb18's Avatar
Default Re: koni and omni (AutoXer)
why does everyone hate on omni? Whats so bad about them? On g2ic I have heard several good things about the omnis. What makes them so bad?
Old Dec 1, 2005 | 04:47 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglessb18 &raquo;</TD></TR><TR><TD CLASS="quote">why does everyone hate on omni? </TD></TR></TABLE>
They're a low quality product.
» Search Results
Your search for omni returned 42 results.
» New Search
That's just recent topics in the suspension forum. 1/2 of them are people complaining about bouncy / stiff ride. The springs are very stiff to be able to 'dump' a car and make up for their low quality. Most people don't run adequate shocks for this, which just compounds the problem. Pick them up if you want, just be prepared that it may not be what you were expecting.
Old Dec 1, 2005 | 10:38 AM
Teglessb18's Avatar
Yes I know and I have searched. But I think I am going to not get the omni coilover setup instead I think I will just save a little more money and look into something like the tein basics. but thank you for the info.
StolenTeg
Suspension & Brakes
Aug 16, 2009 06:09 PM
Luchini
Dec 9, 2006 06:54 PM
toeknee360*
Jul 24, 2006 12:18 PM
JeeXi
Aug 28, 2004 04:44 AM
