Integra Brake MC/BB , GSR Lower control arms, UCAs, LCAs, D-series IM
Old Nov 28, 2005 | 10:16 AM
Redline96LX's Avatar
* B A N N E D *
Default Integra Brake MC/BB , GSR Lower control arms, UCAs, LCAs, D-series IM
Civic Si EM1 99-00 4040 Prop. Valve - $45 Shipped
The Civic Si proportioning valve. A must have for anyone with a EK thats converting to rear discs. This bolts onto any 96-00 Civic, and is needed for swapping rear drums to discs to balance out the brake bias.
Civic Front Calipers - $20
For the 9.5" rotor front brakes, will fit on almost all Honda knuckles, calipers were meant for the 9.5" rotors on non EX/Si civics from 88-00. Good upgrade for the CRX HF, good shape replacement if your calipers broke. Seals are great, come with brackets. From a 96 Civic LX, will go on DX, LX, CX, EX (no ABS 92-95) knuckles on 88-00 Civics.
Civic/Integra 4-lug front hubs (2) - $15
These are the hubs with lug studs in them from a 99 Civic Si. Will fit the bearings of any 88-00 Civic or 90-01 Integra and some other Hondas. 4x100 lug pattern. Lugs are not bent or stripped. Hubs are not bent or broken.
Civic 13/16" Master Cylinder - $30
In fantastic condition, no problems. Bolts onto 98-01 Integra Brake boosters, 96-00 Civic brake boosters.
ABS wheel sensor - $10
Came from a 95 Integra GS front knuckle. Will work on Civics and Integras, and probably many more Hondas with ABS. THis is the pickup sensor which is screwed to the knuckle near the axle to read ABS. Good replacement if yours broke.
D16Y7 Intake manifold - $15
in like new condition, clean, no scratches on face, vacuum line attachment tubes are perfect.
96-98 Sedan 4 door taillights - $40
OEM, Great condition, i kept them waxed all the time. No scratches or nicks, seals are even in great shape.
OEM civic steering wheel, 96-00. - $30 O.B.O.
Good shape, no rips or bends or tears. Light Grey.
96-00 Civic Coupe/Sedan Stock speakers - best offer
These are the stock 6.5" front and 6x9" rear speakers. In almost perfect shape, no scratches at all or bends.
88-00 Civic/90-01 Rear trailing arm and Drum Spindle - 50$ (pickup prefered)
This is the rear drum brake setup on the trailing arm from a 96 civic. Same drums as any 88-00 Civic (except CRX HF - I can't confirm but I believe it had smaller drums). Will go onto an Integra as well, like if your track racing (for the less weight.) Bushing on the control arms are in fantastic shape, about 3 months and 5,000 miles on them. Entire setup is in good condition. Pickup prefered in the Atlanta area because shipping will be about $50.
1995 Integra GSR UCAs - $20
1995 Integra GSR Compensator arms - $10
These are the Rear Upper control arms, Rear compensator arms, and rear trailing arm to a 95 Integra GSR. Will fit all 94-01 Integras and 92-95 civics and Del Sols (since they have all the same suspension.) In great shape, the bushings are all good. come with bolts if you want them. I also have a rear stock rubber brake line from a 95 GSR in good condition like if you ripped one of yours.
1995 Integra GSR LCAs - SOLD
Integra GSR MC/BB combo 15/16" - Bolts onto EGs - SOLD
Modified by Redline96LX at 4:54 AM 1/9/2006
Modified by Redline96LX at 5:11 AM 1/9/2006
Modified by Redline96LX at 6:58 PM 1/10/2006
Old Nov 28, 2005 | 12:10 PM
* B A N N E D *
Default Re: Integra Brake MC/BB , GSR Lower control arms, UCAs, LCAs, D-series IM (Redline96LX)
D16Y8 throttle body sold to slosc2!
Old Nov 29, 2005 | 06:43 AM
* B A N N E D *
ttt
Old Nov 30, 2005 | 06:38 AM
* B A N N E D *
up
Old Nov 30, 2005 | 02:45 PM
* B A N N E D *
ttt
Old Dec 1, 2005 | 08:28 AM
racer_X_123's Avatar
UP for a good seller
Old Dec 1, 2005 | 04:23 PM
* B A N N E D *
thanks
Old Dec 2, 2005 | 08:07 AM
* B A N N E D *
ttt
Old Dec 3, 2005 | 09:50 PM
Archidictus's Avatar
Unceasing Measure
Bump for t3h w1n
Old Dec 3, 2005 | 10:46 PM
* B A N N E D *
Default Re: Integra Brake MC/BB , GSR Lower control arms, UCAs, LCAs, D-series IM (Archidictus)
thanks
Old Dec 4, 2005 | 12:51 AM
* B A N N E D *
ttt
Old Dec 4, 2005 | 12:25 PM
* B A N N E D *
anyone?
Old Dec 4, 2005 | 04:30 PM
* B A N N E D *
bump
Old Dec 5, 2005 | 03:24 PM
* B A N N E D *
GSR LCAs are now on ebay.
Old Dec 5, 2005 | 07:13 PM
* B A N N E D *
ttt
Old Dec 5, 2005 | 08:22 PM
* B A N N E D *
bump...this is how we do it..
Old Dec 6, 2005 | 01:19 AM
* B A N N E D *
to the top we go...
Old Dec 6, 2005 | 06:41 PM
* B A N N E D *
ttt to get rid of this stuff out my garage
Old Dec 6, 2005 | 11:41 PM
* B A N N E D *
ttt
Old Dec 8, 2005 | 08:22 AM
* B A N N E D *
up
Old Dec 8, 2005 | 08:16 PM
* B A N N E D *
ttt
Old Dec 9, 2005 | 12:19 AM
* B A N N E D *
up?
Here we go now. 'Cynthia, she's a really cool dancer. Cynthia, boogie to the groove now.'
Old Dec 9, 2005 | 07:27 PM
* B A N N E D *
bump cause i need some cash really fast
Old Dec 10, 2005 | 12:37 AM
* B A N N E D *
ttt
Old Dec 10, 2005 | 11:14 AM
* B A N N E D *
up
