How much is too much!
Old Nov 28, 2005 | 08:09 AM
blacksihatch's Avatar
Default How much is too much!
I live here in AZ and have a b16a SIRII motor from Japan and would like to run some higher Octane fuel ( AZ highest is 91 ) for normal driving ..sometimes, but mainly when im at the track or roadracing. I think in Japan these engines took 100 Octane.
Any thoughts??
Old Nov 28, 2005 | 08:36 AM
drdisco69's Avatar
Default Re: How much is too much! (blacksihatch)
US and Japanese octane rating are different, and not directly comparable. You can't really have to high of an octane, ie it won't break anything. If your motor is stock, you won't see much gain from it however.
Old Nov 28, 2005 | 10:32 AM
Default Re: How much is too much! (drdisco69)
Well Im not worried about breaking anything and the motor is not stock there are some motor work done, and octane is rated the same eveywhere unless someone can prove different.
Old Nov 28, 2005 | 11:12 AM
West Werks's Avatar
Fuels in the U.S. are described in terms of their "Pump Octane", which is the average of "RON" (Research Octane Number) and "Motor Octane Number". Labels on gasoline pumps in the U.S. typically describe this as the "(R+M)/2 Method".
Some nations describe fuels according to the traditional "RON" or "MON" ratings, so Octane ratings cannot always be compared with the equivalent U.S. rating by the "(R+M)/2 method".
Taken from here: http://en.wikipedia.org/wiki/F...ctane
Old Nov 28, 2005 | 01:05 PM
Default Re: How much is too much! (VenGeanceDrag)
Thanks for the scoop, the link was especially sweet. Good info.
Old Nov 28, 2005 | 01:22 PM
cchhrriiiss's Avatar
I would'nt run anything over 105 without forged pistons. Really no reason to on a stock engine.
Old Nov 28, 2005 | 02:50 PM
Default Re: How much is too much! (ChrisBrown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChrisBrown &raquo;</TD></TR><TR><TD CLASS="quote">I would'nt run anything over 105 without forged pistons. Really no reason to on a stock engine. </TD></TR></TABLE>
I was thinking nothing more than 103
Old Nov 28, 2005 | 08:44 PM
LSVTEC 91 Civic's Avatar
Banned
Use Toulene if you're that worried.. but I see no reason why you need more than 91 octane with a stock B16.
10% Toulene on 91 octane = 92.9
20% = 94.1
30% = 95.5
Don't go higher than 30% (Numbers taken from SCC article on octane boosters)
Old Nov 29, 2005 | 06:05 AM
Default Re: How much is too much! (LSVT3K 91 C1V1C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVT3K 91 C1V1C &raquo;</TD></TR><TR><TD CLASS="quote">Use Toulene if you're that worried.. but I see no reason why you need more than 91 octane with a stock B16.
20% = 94.1
30% = 95.5
Don't go higher than 30% (Numbers taken from SCC article on octane boosters)</TD></TR></TABLE>
Nobody's worried ..did anywhere someone say that ..i did'nt read the forum my motor is not stock, and also what the hell do you care if i run higher octane or just 91
Shinny
15
Aug 28, 2010 01:54 PM
SoFresh1189
Jan 26, 2010 02:32 PM
DJ_NeX
29
Sep 8, 2006 05:30 AM
Solscud007
Dec 27, 2004 04:31 PM
ILOVEGIRLS
Acura TL, RL & ZDX
Oct 26, 2004 07:53 AM
