going from a 2000 civic LX to a 2000 itr ecu.......will it work?
Old Mar 13, 2002 | 09:49 AM
CrOmEdOmEcHaMbEr's Avatar
Default going from a 2000 civic LX to a 2000 itr ecu.......will it work?
I wanna buy an ecu from a 2000 itr for the fuel maps but im not sure if it will fit in....im pretty sure a 2000 itr is OBDII like mine but im not sure......i also need to know if i need to do any kind of mod for it to work right (ie: switch pins).....
Old Mar 13, 2002 | 10:04 AM
fowler!'s Avatar
Default Re: going from a 2000 civic LX to a 2000 itr ecu.......will it work? (CrOmEdOmEcHaMbEr)
Exactly why would you want to use the ITR ecu?
Do you think it's actually going to give you performance gains? Most likely it's just going to mess things up.
Old Mar 13, 2002 | 10:12 AM
Default Re: going from a 2000 civic LX to a 2000 itr ecu.......will it work? (Fowler Yo!)
seriously?? i heard that the fuel maps on there will give me some hp.........
Old Mar 13, 2002 | 10:18 AM
fowler!'s Avatar
No. Plus you don't even have vtec.
It'll just mess things up.
Old Mar 13, 2002 | 10:26 AM
Kamin's Avatar
whoever told you that you should HIT in the FACE
NO it may work but its gonna **** **** up.
if you want to set the a/f ratio, get a VAFC!
[Modified by KAMiN, 11:27 AM 3/13/2002]
Old Mar 13, 2002 | 10:49 AM
Plan B's Avatar
Default Re: going from a 2000 civic LX to a 2000 itr ecu.......will it work? (KAMiN)
Okay, first it will throw codes like crazy, your engine has no knock sensor, hence it will always have a check engine light. If you really want to use another ecu, buy a skunk 2 harness adapter, and get a chipped p28 for non-vtec race application. I'm actually using a mugen chipped b-series ecu on my 94 civic ex with the stock d16z6(shaved head, bolt ons). It runs great, i'm afraid i'm gonna float a valve revving it to 8800 everyday.
Just my .02
btw: that ecu has the knock-sensor disabled.
[Modified by Plan B, 3:27 PM 3/13/2002]
Old Mar 13, 2002 | 11:28 AM
Avante's Avatar
Default Re: going from a 2000 civic LX to a 2000 itr ecu.......will it work? (Plan B)
The itr ecu, or any ecu is programmed and made for a specific engine. In this case, the ITRs 1.8liter engine. Even if you rewired everything so the engine actually runs, there would be waaay too much fuel for your 1.6 litere sohc in your car. Also if you actually try revving the engine to close to 9 grand which the ITR engine will let you, you are pretty much guaranteed that you will blow your motor.
Old Mar 13, 2002 | 12:06 PM
Plan B's Avatar
Default Re: going from a 2000 civic LX to a 2000 itr ecu.......will it work? (Avante)
It did act a little screwey at first. But now it runs great, i just had to tune down my FPR a little and i really enjoy it.
xtcat9k
Oct 25, 2004 01:18 PM
quickcoupe
Sep 16, 2003 04:24 AM
NSX Bob
Jun 3, 2003 08:03 PM
