leaking head gasket
Old Nov 27, 2005 | 09:37 PM
livinlow's Avatar
Default leaking head gasket
I don't have any coolant in my oil or vice versa, good compression on my gs-r turbo, but after I shut the car off after I've been in boost for a bit I'll notice a little bit of oil between the corner of the head and block near the transmission. Never seen or heard of it but just asking if anyone has had a smiliar problem? I'm going to change the head gasket out quick with some ARP studs before I actually blow the whole thing.
Old Nov 27, 2005 | 11:30 PM
Dartanian's Avatar
Default Re: leaking head gasket (livinlow)
Sounds like you have a good plan of action for fixing this. I would imagine that the problem will subside when the gasket has been replaced and the studs properly torqued. Also, make sure the head is flat.
Old Nov 27, 2005 | 11:54 PM
LSvtec03's Avatar
http://www.team-integra.net/se...D=576
hamizle
Dec 1, 2009 04:55 PM
turbodailydan
Jul 19, 2009 07:54 PM
umair
Jun 30, 2008 04:51 PM
Screamer
Apr 15, 2003 05:50 AM
