WTB: Many b18 LS parts.....
WTB:
-b18a1 Oil Pan
-b18a1 oil sump
-b18a1 crankshaft
-b18a1 wedge tray, or whatever that thing is called.
-studs for b18a1
- b18b1 drivers side moutn bracket
- Brackets to mount the enigne except for drivers side off a b18a1.
- b18a1 dipstick
- b18a1 timing belt cover
-b18a1 crank pulley
-TPS Sensor
-Any B Series Exhaust gasket
Im sure most of the b18a1 and b18b1 parts share same characteristics. Correct me if im wrong, but i think the drivers side mount bracket is the only difference. Whatever as long as it works on the block.
- Clutch capapble of 450hp+, preferrably sprung street clutch.
- Fuel Pressure Regulator
-Oil Feed/Oil Send Lines for turbo
- The oil sender sensor with the 2 extra ports, one for turbo one for ls vtec kit
- bolts that go from throttle body to intake manifold
- Golden Eagle LS VTEC conversion kit.
Need ASAP.
Thanks
Modified by JDM00SI at 6:38 AM 12/1/2005
-b18a1 Oil Pan
-b18a1 oil sump
-b18a1 crankshaft
-studs for b18a1
- b18a1 dipstick
-b18a1 crank pulley
-TPS Sensor
Need ASAP.
Thanks
LS-VTEC-TURBO-EF9
Apr 14, 2011 02:41 PM
dfoxengr
Apr 18, 2006 09:10 AM
akhom
Oct 15, 2005 09:57 PM
