Almost complete Engineering project....nothin special
Old Nov 27, 2005 | 07:24 PM
m R g S r's Avatar
Default Almost complete Engineering project....nothin special
I used the trebuchet thingy idea.....probally gonna complete it tomorrow and test this bad boy out!!
here...for refference:
https://honda-tech.com/zerothread?id=1403061
Modified by m R g S r at 10:49 PM 11/30/2005
Old Nov 27, 2005 | 07:30 PM
Chase's Avatar
Default Re: Almost complete Engineering project....nothin special (m R g S r)
uh huh....hmm....so what is it? What does it do? Looks coo tho
Old Nov 27, 2005 | 07:42 PM
m R g S r's Avatar
Default Re: Almost complete Engineering project....nothin special (EF8kid)
sry...search my name and you will see the thread....hold on ill post it for refference
Old Nov 27, 2005 | 07:46 PM
k24em2's Avatar
If its meant to throw something idk how well thats gonna work.
Old Nov 27, 2005 | 07:48 PM
m R g S r's Avatar
Default Re: Almost complete Engineering project....nothin special (k24em2)
did you read the thread? its a tug o war...
Old Nov 27, 2005 | 08:13 PM
.dave's Avatar
i HAS questions ?
Is it just sitting on the plywood and then the tugging spring is attached to the top of that arm?
Old Nov 27, 2005 | 08:38 PM
weiRtech's Avatar
OG Fabricator
Default Re: Almost complete Engineering project....nothin special (daveG)
looks like it will work to me. hope you are using strong springs and have spares. could you double them up and have 4 in a row instead of just the 2?
Old Nov 27, 2005 | 08:43 PM
.dave's Avatar
i HAS questions ?
Default Re: Almost complete Engineering project....nothin special (weirRacing)
I'm really not following how this is supposed to work. Is the tug spring in equilibrium to begin with and attached at the top of the arm (opposite your other two vertical springs)? If thats the case, unless you're springs are under tension to begin with I don't really see this doing anything other than sitting there.
Old Nov 27, 2005 | 09:04 PM
k24em2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveG &raquo;</TD></TR><TR><TD CLASS="quote">I'm really not following how this is supposed to work. Is the tug spring in equilibrium to begin with and attached at the top of the arm (opposite your other two vertical springs)? If thats the case, unless you're springs are under tension to begin with I don't really see this doing anything other than sitting there. </TD></TR></TABLE>
thats where im sitting...how does it work, where does it pull from?
Old Nov 27, 2005 | 09:18 PM
.RTErnie's Avatar
This thread is worthless without more information.
Old Nov 27, 2005 | 09:19 PM
weiRtech's Avatar
OG Fabricator
i believe the arm is in the resting position in the first pic. when you push the rod toward the other side it will create tension on the springs. you hook the arm up to whatever you want to pull and let the springs do their job. it will want to pull back to the resting position. atleast that is how i see it working. just make sure the base is anchored to something damn heavy.
Old Nov 28, 2005 | 12:00 AM
AspectIndustries's Avatar
Default Re: Almost complete Engineering project....nothin special (RTErnie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTErnie &raquo;</TD></TR><TR><TD CLASS="quote">This thread is worthless without more information. </TD></TR></TABLE>
Old Nov 28, 2005 | 02:21 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">
couldnt you drill the holes for that bar, in front of these 2 uprights and mount the srpings on an angle, so that the base is in the front of the tower, i belive it would work better this way? or even drill the hole for the cross bar directly below the pivot point(all the way at the bottom) ......
anyone care to argue with me?
Old Nov 28, 2005 | 02:57 AM
m R g S r's Avatar
Default Re: Almost complete Engineering project....nothin special (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote"> couldnt you drill the holes for that bar, in front of these 2 uprights and mount the srpings on an angle, so that the base is in the front of the tower, i belive it would work better this way? or even drill the hole for the cross bar directly below the pivot point(all the way at the bottom) ......
anyone care to argue with me? </TD></TR></TABLE>
was gonna do that but when the arm was pulled down the springs would hit the pivot point....plus they are very very heavy springs....42lbs each i think? its a bitch to push down the arm as it is now!!
And yes....its not done yet!!!!!! The arm is in the equilibrium position now...That tiny ledge looking thing is going to be where the latch sits. When the arm is pushed down under tension it will be grabbed by the latch. There will be a hook at the end of the arm on the side that you cant see in the pic. That attaches to the spring which attaches the two competitors.
The latch is then released and the arm shoots up and back somewhat. Not the best design, but ohh well!!
Old Nov 28, 2005 | 07:40 AM
beepy's Avatar
Did you figure out what to do to make it actually pull? I assume this is the raised pull point idea that was tossed around to kinda step around the rules?
Old Nov 28, 2005 | 01:59 PM
m R g S r's Avatar
Default Re: Almost complete Engineering project....nothin special (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Did you figure out what to do to make it actually pull? I assume this is the raised pull point idea that was tossed around to kinda step around the rules?</TD></TR></TABLE>
sorta.....i guess we are just going to rely on the initial jolt and the spring attaching the two to help get it moving.....
Old Nov 28, 2005 | 02:22 PM
.dave's Avatar
i HAS questions ?
Is it going to be able to pull enough without tipping over? Is the base heavy enough?
Old Nov 28, 2005 | 03:54 PM
m R g S r's Avatar
gonna add weight when its all done..
it can be 10lbs...it WILL be 10 lbs lol
Old Nov 28, 2005 | 04:30 PM
Riake's Avatar
Semi - off topic, but not really at the same time...
I was just in a marshmallow launching competition. My design, looks somewhat similar to yours. Many of the competitors used compressed air with PVC, but we decided to try something original.
Simple design, but it worked really well, we got within 3 inches of the 1 foot diameter target from 50 ft away.
Old Nov 28, 2005 | 06:16 PM
m R g S r's Avatar
Default Re: Almost complete Engineering project....nothin special (Riake)
nice nice...but that mo Fo is hugeeeee compared to ours
we were limited to a 10"x6"x8" size constraint....
Old Nov 28, 2005 | 06:24 PM
cptengineer's Avatar
Statics or Dynamics project?
Old Nov 28, 2005 | 06:54 PM
m R g S r's Avatar
Default Re: Almost complete Engineering project....nothin special (cptengineer)
introduction to engineering...im a freshmannnn
Old Nov 28, 2005 | 06:59 PM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">introduction to engineering...im a freshmannnn </TD></TR></TABLE>
Good luck with the project. What school are you at?
Old Nov 28, 2005 | 09:53 PM
m R g S r's Avatar
manhattan college...thanks btw
Old Nov 28, 2005 | 09:57 PM
Riake's Avatar
'05 fresh here too, UCF for me, our limit was $25 - no size limit
Also same class Into to Eng profession
