manual transmission fluid fill level
Old Nov 27, 2005 | 04:27 PM
4NOWJUSTADX's Avatar
Default manual transmission fluid fill level
how much transmission fluid should i put in the car. i have been told to 1. remove the speedometer gear and fill it up entirely and i have been told to 2. just put 2 quarts in. which is best. sorry for the stupid question
Old Nov 27, 2005 | 04:48 PM
vancoland's Avatar
here, just use this link and scroll down to where he fills the tranny fluids
https://honda-tech.com/zerothread?id=382416
pour it through the vss and find out how much fluids your tranny takes....or you could pull the fill plug and wait for it to leak out of there, but you might have to replace the crush gasket
Old Nov 27, 2005 | 04:50 PM
.Beaver's Avatar
Bloody Beaver
Default Re: (vancoland)
D series 1.9qts
B series 2.5qts
Old Nov 27, 2005 | 04:56 PM
nocturnaldragon's Avatar
Default Re: manual transmission fluid fill level (4NOWJUSTADX)
No no no no no,
Take out the speedo cause its easier to fill into the hole on the top then the side. Now remove the TOP plug on the side, Fill it up untill it runs out of that hole. Replace both and your set to go.
Old Nov 27, 2005 | 04:57 PM
.Beaver's Avatar
Bloody Beaver
Default Re: manual transmission fluid fill level (nocturnaldragon)
OR you can just remove the speed sensor and add 1.9qts for D series or 2.5qts for B series. If you know how much it takes then why do the messy *** oil running out the hole thing.
Old Nov 27, 2005 | 05:01 PM
Default Re: manual transmission fluid fill level (Leeroy)
You can never be 100% the transmission is bone dry so I use that methode just to be sure. But your way works as well I just prefer mine.
Old Nov 27, 2005 | 05:08 PM
vancoland's Avatar
its hard to find the fill plug gasket at the dealership if you lose it or break it
luv2boost
Aug 8, 2007 10:06 PM
2mansi
Aug 15, 2006 01:08 PM
budomove
Jun 25, 2006 05:02 PM
hatch_
Apr 17, 2006 05:05 PM
slowman
Mar 31, 2004 12:41 PM
