H23VTEC w/ H22 connecting rods/pistons
Old Nov 27, 2005 | 04:10 PM
brycemartin's Avatar
Default H23VTEC w/ H22 connecting rods/pistons
I am working on rebuilding an H22A1 and I am basically making a H23VTEC. I am putting an H23 crank in and I am wondering if it is ok to use the H22 connecting rods and pistons. Will this clear the valves? Thanks in advance.
Oh, before you guys say go to the thread about the H23VTEC, there is no mention of using the H22 rods that I could find. Any help on this would be great.
Old Nov 27, 2005 | 04:37 PM
fastludeh22's Avatar
Default Re: H23VTEC w/ H22 connecting rods/pistons (brycemartin)
there is no mention of it, cause you cant do it. the h22 rod/piston combo is too long. if you had a custom piston made with the pin moved up you could, but that would require resleveing the block.
Old Nov 27, 2005 | 05:05 PM
Default Re: H23VTEC w/ H22 connecting rods/pistons (fastludeh22)
Thanks for the reply. Looks like I am going to look for some H23 rods.
Old Nov 27, 2005 | 05:19 PM
One last question, do you know if it is ok to use the H22 pistons with the H23 rods? Thanks.
Old Nov 27, 2005 | 05:28 PM
mgags7's Avatar
yes, as found in the h23vtec thread, this will work....
Old Nov 27, 2005 | 05:42 PM
thanks for the replies, i appreciate it.
93h2beg
Jan 13, 2011 08:38 AM
yohan
Sep 23, 2004 11:39 PM
hOndafienD 04
Sep 22, 2004 11:17 AM
JDMBB2
Nov 13, 2003 10:39 AM
flip1199
Oct 24, 2003 03:57 PM
