Suspension & Brakes Theory, alignment, spring rates....
95 Accord lower rear control arms???
Old Nov 27, 2005 | 03:25 PM
Accorn's Avatar
Default 95 Accord lower rear control arms???
Does anyone know where I can find after market rear lower control arms for my 95 accord? Ive already searched and all I came up with is oem replacement. Thanks.
Old Nov 28, 2005 | 09:34 AM
Accorn's Avatar
Bump
Old Nov 28, 2005 | 09:03 PM
Accorn's Avatar
Night Bump
Old Nov 29, 2005 | 09:37 PM
Accorn's Avatar
Anyone????
Old Dec 1, 2005 | 12:08 AM
XaznKewLguyX's Avatar
Default Re: 95 Accord lower rear control arms??? (Accorn)
i got ingalls one at my local shop for 150 both fronts
Old Dec 1, 2005 | 07:58 AM
Accorn's Avatar
Thanks for the info, but im looking for rears.
Old Dec 1, 2005 | 08:07 AM
MinuteRice's Avatar
Default Re: (Accorn)
Bumb because his car is all over the road when he drives in the snow and i'm scared to ride with him!!
Old Dec 1, 2005 | 08:36 PM
Accorn's Avatar
UP
Old Dec 1, 2005 | 08:55 PM
the rear is not ball joints you can use home depot washers thats what i use search it
Old Dec 1, 2005 | 11:24 PM
Accorn's Avatar
I need whole new lower rear control arms. Mine are bent. I was wondering if anyone knew if there are after market ones availible. I have searched and found nothing except upper control arms, and ones for the front, which I am not interested in right now.
Old Dec 1, 2005 | 11:41 PM
ohhhhhhh lol ok sorrry for angering you if i have
Old Dec 2, 2005 | 08:34 AM
Accorn's Avatar
Nope not angry, just want control arms.
Old Dec 2, 2005 | 05:57 PM
Accorn's Avatar
Bump
Old Dec 2, 2005 | 06:08 PM
.RJ's Avatar
.RJ
Just get OEM... anything aftermarket is going to likely be weaker, especially the cheap ebay ****.
Old Dec 2, 2005 | 09:17 PM
Accorn's Avatar
I figured I might upgrade the bars since I have to replace one of them anyways. Im just looking to see if there are any availible, since I have found none.
Old Dec 3, 2005 | 08:52 PM
Accorn's Avatar
Up
Old Dec 4, 2005 | 05:13 PM
Accorn's Avatar
Bump
Old Dec 4, 2005 | 05:19 PM
.RJ's Avatar
.RJ
Why are you set against using the OEM parts?
Old Dec 4, 2005 | 07:23 PM
Accorn's Avatar
I'm not. Alot of companys make after market control arms for just about every other honda, I just wanted to know if someone knew about ones for mine since I couldnt come up with anything. I'll probibly end up using OEM and just throw some energy bushings in.
Old Dec 4, 2005 | 07:25 PM
.RJ's Avatar
.RJ
If you buy new oem, they come with new bushings pressed in, ready to go Best solution, IMO.
Old Dec 4, 2005 | 07:27 PM
Accorn's Avatar
I was planning on buying a bushing kit, I have other bushing that are bad, and I wanted to try to tighten up the suspension a little bit.
Old Dec 5, 2005 | 04:47 AM
.RJ's Avatar
.RJ
New OEM bushings are better off. The poly stuff doesnt last very long on the street.
Old Dec 6, 2005 | 06:23 AM
Accorn's Avatar
Everything that ive heard, is that they will last longer and be more efficient then the rubber ones.
Old Dec 6, 2005 | 07:09 AM
accordhybrid's Avatar
They don't make aftermarket lower control arms. I know a buddy that had some custom made.
Old Dec 6, 2005 | 07:26 AM
iakona's Avatar
well, you have two options. get custom ones made up (like i have), or get some used oem ones (which i just happen to have an extra set of).
if you're serious, and i mean serious about a set of rear LCAs, let me know. but come with cash.
