butterfly valve for h22
Old Nov 27, 2005 | 02:12 PM
bb4socal's Avatar
Default butterfly valve for h22
Just wondering has anyone tried to mock up the Intake plenum and Runners without the butterfly valve in the middle on any I.M. that uses a butterfly valve?
-Would it make any difference power wise, to remove the valve? You might lose torque but gain hp.
I took mine apart to see hwo it would line up and it seems ok. maybe a lil modification to the gasket that goes between. Also shorter screws and some spacers would be needed.
Put yoru opinion down or your experience with the IM.
Old Nov 27, 2005 | 02:32 PM
2lude4u's Avatar
Default Re: butterfly valve for h22 (bb4socal)
I did a dyno test awhile ago. It's a little different than what you're suggesting but it will give you an idea. Basically it provides good top end but you sacrifice torque/power between 3700-4500 rpm.
https://honda-tech.com/zerothread?id=1310148
Modified by 2lude4u at 4:42 PM 11/27/2005
Old Nov 27, 2005 | 02:41 PM
VTECRaZeR's Avatar
Is not worth the sacrific I don't think. You need that torque to get you going. I have a Skunk2 manifold and they don't have butterflies and let me tell you that if it did It would make more power, Its probably because of the loss in air velocity. So I'm going back to stock ported and polished.
Old Nov 27, 2005 | 02:49 PM
bb4socal's Avatar
GOOd info...thanks for the replies. SO the official name for the Butterfly valve is IAB's? does that stand for Intake Air Bypass?
mortificationrock
27
Sep 7, 2010 01:10 PM
mho85
May 5, 2009 10:04 PM
Trbospnkr
May 26, 2003 01:20 PM
Accord15
Feb 6, 2003 04:33 PM
