h23 - h22 swap. green plug by radiator hose
Old Nov 27, 2005 | 10:43 AM
shutta's Avatar
Default h23 - h22 swap. green plug by radiator hose
On the h23 wiring harness there is a green plug that is bunched up with the plugs for the distributer, on my h22, there is no male end on the head where the hose connects, do I just swap the part from the h23 or do I need to plug it in somewhere else?
Old Nov 27, 2005 | 03:14 PM
shutta's Avatar
anyone?
Old Nov 27, 2005 | 03:25 PM
Fly1865's Avatar
Default Re: (shutta)
just use the H23 one.
Old Nov 27, 2005 | 04:34 PM
BB6racer's Avatar
the harness sounds like the coolant temp sensor, or fan switch. the harness in your car is for a h23, but now that you have a h22 motor and ecu you won't need it. just leave it unplugged IMO.
Old Nov 27, 2005 | 05:32 PM
Sabbotage's Avatar
yeah when i did mine i just zip tied that plug out of the way. I didnt wanan break the seal on the neck to risk trying to use it so i just tied it out of the way and hid it. Works fine.
Old Nov 28, 2005 | 07:40 AM
shutta's Avatar
well where on teh h22 is teh coolant temp sensor? if it's not there it must be somewhere else... hmm
Old Nov 28, 2005 | 07:48 AM
pentaq's Avatar
This is a fan switch for sure. It plugs to the elbow coming out from the head in H23. You can swap this elbow also.
92lude76
Nov 25, 2007 07:39 AM
Sabbotage
Sep 28, 2004 08:43 PM
FleXingMyEK
Nov 22, 2002 12:45 PM
1.8EG-T
May 15, 2002 05:34 PM
