half sized, dual core, fluidyne radiator?
Old Nov 27, 2005 | 10:24 AM
numotive's Avatar
Default half sized, dual core, fluidyne radiator?
i need to upgrade my radiator, and was wondering, since i plan on boosting in the future, should i get a half sized radiator? if so what would be a good kind to purchase - i always hear the names koyo and fluidyne, so i'm guessing these would be some reputable names two choose from? which half size ones would fit a 99 gs-r? also, do these radiators use a different kind of coolant, or do they use the same kind a normal OEM radiator would use?
Old Nov 27, 2005 | 12:42 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: half sized, dual core, fluidyne radiator? (numotive)
They are all good radiators. Keep in mind that cooling isn't really an issue even at high power levels. It's mostly for security just in case. Besides, the OEM one has plastic endtanks that like to crack at about 80-100K miles.
I have heard that Fluidyne isn't a true dual core, but since I never considered buying a Fluidyne, I never looked into it further. Their expensive slim fans also turned me away. I believe the fans are more expensive than the damn radiator.
Look into C&R. They are a little more pricey, but they are great. They come with their own 1000CFM SPAL slim fan. Very nice. True dual core, and they come in a half or full size.
Here was mine:
Old Nov 27, 2005 | 01:12 PM
.water's Avatar
^^^^sick radiator.
i think we have sponser that sells Koyo rad for $300
Old Nov 27, 2005 | 03:18 PM
loudassVTEC's Avatar
I upgraded to the Full-Race half-sized radiator. I was extremely impressed with the quality, and performance.
Old Nov 27, 2005 | 03:21 PM
Danziver's Avatar
Default Re: half sized, dual core, fluidyne radiator? (loudassVTEC)
I use a dual core koyo. No problems so far.
Old Nov 27, 2005 | 05:13 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: half sized, dual core, fluidyne radiator? (Danziver)
^^ all good, look at a OEM SI del sol.
Old Nov 28, 2005 | 01:18 PM
numotive's Avatar
so these all use the same kind of coolant a stock radiator uses, correct?
Old Nov 28, 2005 | 02:05 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numotive &raquo;</TD></TR><TR><TD CLASS="quote">so these all use the same kind of coolant a stock radiator uses, correct?</TD></TR></TABLE>
Yes sir.
Old Nov 28, 2005 | 04:43 PM
CA6VTEC's Avatar
Default Re: half sized, dual core, fluidyne radiator? (shamoo)
<FONT COLOR="royalblue"> I have full size Fluidyne Rad no fans for my N/A motor. Daily Driven. </FONT>
Old Nov 28, 2005 | 05:05 PM
Default Re: half sized, dual core, fluidyne radiator? (CA6VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CA6VTEC &raquo;</TD></TR><TR><TD CLASS="quote"><FONT COLOR="royalblue"> I have full size Fluidyne Rad no fans for my N/A motor. Daily Driven. </FONT></TD></TR></TABLE>
I hope you don't sit in traffic for long. Even with all the cooling capabilities of that radiator, with no airflow, it's not going to cool much. Give it about 15 minutes in a traffic jam, and watch the needle start climbing. Trust me, I used to make 4 hour commutes to and from Washington DC, which was a distance of 60 miles one way. Didn't get over 10mph the whole way. My rad fans quit one day, and I had to pull over and let the engine cool after about every ten minutes of sitting there.
Old Nov 28, 2005 | 05:09 PM
adseguy's Avatar
OEM Del sol v-tec half size radiator in a 328whp integra. This means I downgraded the cooling system and upped horsepower. I haven't had any problems. I don't see the point of buying an expensive radiator exept for bling . One doesn't "cool" better then the other because the thermostat controls that.
HankYee
Aug 14, 2009 12:58 PM
str8JDMteggy
Dec 19, 2006 08:16 AM
BOOSTED_JDM_DB8
Jan 20, 2006 12:49 PM
speedaholic92
Oct 28, 2002 04:31 AM
GTEater
Aug 30, 2001 03:36 PM
