K20 into EK with EG cross member,, which rear support?
Old Nov 27, 2005 | 03:44 AM
Garrett's Avatar
Default K20 into EK with EG cross member,, which rear support?
We are actually doing a k20 swap into a civic 96
this civic had a civic EG 92-95 rear cross member
does the civic K20/EK rear engine mount will works?
Old Nov 27, 2005 | 01:02 PM
Garrett's Avatar
Default Re: K20 into EK with EG cross member,, which rear support? (Garrett)
up
Old Nov 28, 2005 | 05:02 PM
Garrett's Avatar
up
Old Dec 1, 2005 | 01:52 PM
Garrett's Avatar
where are the k20 guru's?
Old Dec 1, 2005 | 02:11 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garrett &raquo;</TD></TR><TR><TD CLASS="quote">where are the k20 guru's?</TD></TR></TABLE>
At K20.org. Thats the place for all your k20 needs.
Old Dec 2, 2005 | 05:10 PM
project_K's Avatar
k-series.com
Old Dec 5, 2005 | 04:29 PM
Jon V's Avatar
Default Re: K20 into EK with EG cross member,, which rear support? (Luserkid)
You need to use the Hasport Ekk2 engine mounts...
They are made for an Ek with an EG/DC rear crossmember and steering rack.
They will give you better ground clearance, axle angle, and engine placement...
Old Dec 5, 2005 | 04:36 PM
Garrett's Avatar
Default Re: K20 into EK with EG cross member,, which rear support? (Jon V)
thanks you very much for you great info Jon V
Old Dec 5, 2005 | 05:26 PM
Jon V's Avatar
K20a.org &gt; All
Old Dec 5, 2005 | 05:40 PM
litterbox's Avatar
I am a (Trial User) Army
I confirm jon v's info, just in case you had doubts.
Scooter426
Jul 3, 2011 10:08 PM
p nut
Oct 21, 2010 11:31 AM
THEDirtyDseriesWOOT
Suspension & Brakes
Aug 14, 2007 10:41 PM
chad
Dec 15, 2003 01:21 PM
rolow
Nov 8, 2002 06:07 AM
