HOW DID MY SINGLE CAM BLOW???!
hey i let my friend drive my ek with a stockd single cam motor with bout 99k milage.. it blew on the freeway when he was goin 105 on 3rd gear bout 8k RPM. he said it was cuz im low on OIL and that i cant blow like that cuz it would tap out, but i heard someone else say that single cams dont tap out.. HELP??
Low Oil means there isnt enough oil to keep all engine components lubricated.. stuff that isnt lubricated will create friction and heat.. too much friction and heat stuff breaks so that is prolly why you blew your engine..
Also that motor isnt suppose to see anything more than 7000 RPMS MAX! and u had it at 8000 RPMs... that could be a big issue as well.
LOL tap out.. thats a first.
Its called a Rev Limit. You can blow any motor do a long burn out and bounce off the rev limit and watch what happens. causes alot of stress on the motor and it will go BOOM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">Low Oil means there isnt enough oil to keep all engine components lubricated.. stuff that isnt lubricated will create friction and heat.. too much friction and heat stuff breaks so that is prolly why you blew your engine..
Also that motor isnt suppose to see anything more than 7000 RPMS MAX! and u had it at 8000 RPMs... that could be a big issue as well.</TD></TR></TABLE>
well, if his MOTOR BLEW, and then he checked his OIL, woudlnt some oil have been lost in the process of it blowing by the friction and heat, therefore when he CHeCkeD HIS OIL AFTer the motor BLEW, it could not be accurate about the OIL LEVEL?
ya his level would be low.. but he doesnt say anything about checking it before hand.
Im going off assumption that his motor burnt some oil and Excessive RPM"s caused the motor to blow.
over-rev and spun a rod bearing, or just slung a rod. your friend must be a ******* idiot for taking your car to that high of RPM's, any stock single cam will not hold together above 7k. for very long
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg2wes »</TD></TR><TR><TD CLASS="quote">over-rev and spun a rod bearing, or just slung a rod. your friend must be a ******* idiot for taking your car to that high of RPM's, any stock single cam will not hold together above 7k. for very long</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">I blew up 3 single cam motors all from spun bearings.</TD></TR></TABLE>
Add mine to the list. I've taken my ol' y8 to the land of 8k rpms (god rest her soul) but that was not a happy place for us......
my y8 in third gear redlines at 90mph.
Don't you think since he was going 15mph over that that he probably rev'd too far and spun the bearing?
you = idiot for letting him dirve and letting him tell you that
him = idiot for blowing the motor and for lying to you (and for clearly not having any knowledge of cars whatsoever)
i just blew my second single cam yesterday doin basically the same thing but the rev limiter never kicked in but i pulled the engine apart and the pistons hit the valves on 3 cylinders im guess cuz the vavle springs were strong enough and the clearances were 2 tight did u pull ur engine apart 2 look at it
dont borrow your car to a friend, of course he is going to "test" the car and beat the living hell out of it. wouldnt anyone "test" it? the gas isnt yours, the wear and tear on the engine isnt yours, and you want to have fun.
theres just some things you wouldnt do to your own car that you would do to others, simple as that.
that is true, trust me. taken to plenty of trips to 7-7.5 with my z6
well first of all revving a stock internally single cam to 8k. even a built single cam at 8 grand can live so long. bearings spin all the time. yeah that was your one mistake, runing low on oil is another.
Take the motor apart and that will tell what happened. If your motor did'nt burn or leak oil to start with then it was probably from being overreved. No mater what happened the rpm's had somthing to do with it.
jeez, atleast it was a stock single cam motor, and not an b series
. also never let ur friends drive ur car cuz wen i drive my friends i "test" the hsit out em.
