which brand of rear camber kit is the best for 94-01 integra??????
Old Nov 27, 2005 | 12:16 AM
tkycgo's Avatar
Default which brand of rear camber kit is the best for 94-01 integra??????
I already have a skunk2 front camber kit. (And I will replace the oem ball joint boot)
Now, I need to consider about the rear kit.
1. Anyone can give me advice that which brand is the best?
https://honda-tech.com/zerothre...97850
(I won't consider to buy skunk2 rear kit.)
2. Where is more cheapest for the alignment in san francisco?
Thanks all kindly guys ~~~~
Old Nov 27, 2005 | 12:43 AM
RaceMyGhost's Avatar
Default Re: which brand of rear camber kit is the best for 94-01 integra?????? (tkycgo)
i have the omnipower rear camber kit (not the shim kit) and no complaints here, fully adjustable, great quality. 2 thumbs up
Old Nov 27, 2005 | 12:46 AM
JDMKid05's Avatar
Why not just get a shim kit?
Old Nov 27, 2005 | 12:51 AM
tkycgo's Avatar
Default Re: (JDMKid05)
shim kit, one washer is around 0.5 degree
If I need to adjust 1.3 or 1.6 or more, how to do with this slim kit?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMKid05 &raquo;</TD></TR><TR><TD CLASS="quote">Why not just get a shim kit?</TD></TR></TABLE>
Old Nov 27, 2005 | 01:06 AM
JDMKid05's Avatar
you could just add more washers
Old Nov 27, 2005 | 01:27 AM
tkycgo's Avatar
one washer is 0.5 degree, 1.5 degrees needs 3 washers.
How about 1.3 degrees, how to calculate it?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMKid05 &raquo;</TD></TR><TR><TD CLASS="quote">you could just add more washers</TD></TR></TABLE>
Old Nov 27, 2005 | 06:51 AM
Padawan's Avatar
Darth ModerVader
Default Re: (tkycgo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tkycgo &raquo;</TD></TR><TR><TD CLASS="quote">one washer is 0.5 degree, 1.5 degrees needs 3 washers.
How about 1.3 degrees, how to calculate it? </TD></TR></TABLE>
Why would you need it adjusted to that exact of a level?
Old Nov 27, 2005 | 03:17 PM
tkycgo's Avatar
Default Re: (Padawan)
Before alignment, we don't know how many degrees need to adjust.
If I install this rear shim kit, it won't make sure the wheel perfectly to adjust the correct 0 degree if need to adjust +/- 1.2, 1.3 or 1.4 (example only)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
Why would you need it adjusted to that exact of a level? </TD></TR></TABLE>
Old Nov 27, 2005 | 03:30 PM
verbal_assassin's Avatar
i wouldnt go cheap and get washers. thats just me.
i bought the sprint rear camber kit which replaced the entire arm. and is adjustable to i dont know 4 degrees.....
perfect kit in my opinion or any kit which replaces the entire arm.
i have the front ingalls and they work like shlt. thats what happends when u go cheap. instead of buying the complete kit, i went for the cheaper one which didnt replace the arm and guess what, everytime i hit a big dip, my ball joint or whatever hits my strut tower cauing two BAD dents.
Old Nov 27, 2005 | 03:38 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tkycgo &raquo;</TD></TR><TR><TD CLASS="quote">Before alignment, we don't know how many degrees need to adjust.
If I install this rear shim kit, it won't make sure the wheel perfectly to adjust the correct 0 degree if need to adjust +/- 1.2, 1.3 or 1.4 (example only)</TD></TR></TABLE>
Why would you want 0 degrees of rear camber? The washers or shims (with longer bolts if necessary) will be perfectly sufficient, and I really wouldn't consider it "going cheap", but simply not spending money unnecessarily.
Old Nov 27, 2005 | 03:40 PM
tkycgo's Avatar
Default Re: (verbal_assassin)
That's mean, your opinion is sprint rear camber kit which is a good choice?
It's better than using a shim kit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by verbal_assassin &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt go cheap and get washers. thats just me.
Old Nov 27, 2005 | 03:45 PM
tkycgo's Avatar
Alignment is for making the wheel go straight, right?
If my wheels need to adjust +1.2 degrees, how to use shim kit to adjust this situation?
Why would you want 0 degrees of rear camber? The washers or shims (with longer bolts if necessary) will be perfectly sufficient, and I really wouldn't consider it "going cheap", but simply not spending money unnecessarily. </TD></TR></TABLE>
Old Nov 27, 2005 | 03:53 PM
Pnoyej6's Avatar
* B A N N E D *
I just use round galvanized washers and it made my rear camber pefect. only 2 bucks spent but rear rubs a little so i will remove one washer
Old Nov 27, 2005 | 04:21 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tkycgo &raquo;</TD></TR><TR><TD CLASS="quote">Alignment is for making the wheel go straight, right?
If my wheels need to adjust +1.2 degrees, how to use shim kit to adjust this situation?</TD></TR></TABLE>
A certain amount of negative camber is desirable in almost all cases. If your rear camber is -1.2 degrees, you don't need any correction at all. You really won't have an issue using the washers or shims, but if you'd prefer to spend $100+ to achieve essentially the same results, you're certainly entitled to do so. One thing I would suggest doing before you begin modifying the suspension is researching different setups and the effects that various adjustments can produce.
Old Nov 27, 2005 | 06:30 PM
teknoracing's Avatar
revo technica camber kit
Old Nov 29, 2005 | 01:53 PM
LowTEC-Derbo's Avatar
one of the best is SPC rear camber kit.
one of the best places I've seen that has good service is http://www.autoinnovations.com in terms of alignment.
Located in Milpitas, CA and they do alignments faily decent price. Definitely a great deal since their alignment rack is tuner friendly with a low degree ramp for those lowered vehicles.
Even better is that they also adjust camber if you have the camber kits and are very aware of what they are doing.
Old Nov 29, 2005 | 03:20 PM
Danronian's Avatar
Unless your car is 3 inches lowered i wouldnt even use any type of rear camber correction b/c a good alignment equals perfect rear tire wear on a lowered car.
Old Nov 29, 2005 | 03:33 PM
projectPSI's Avatar
Default Re: (crazyxzer0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyxzer0 &raquo;</TD></TR><TR><TD CLASS="quote">one of the best is SPC rear camber kit. </TD></TR></TABLE>
How do you figure 1 washer is .5 degree camber. You do know they make washers in different thincknesses, I'm sure i can use 1 thinker washer and get 1 degree of camber or what not.
Old Nov 29, 2005 | 07:58 PM
Default Re: (projectPSI)
I am pretty much barely any fender room inbetween my tire and fender.
I have 1.8 and 2.1 degrees of negative in the rear of my car.
the front has 2.5 and 2.3 degress of negative in the front.
I dunno what the affects are on my tires yet but I will know soon enough. I already got Skunk2 Front camber kits (new pro ones) and planning to buy the SPC rear ones.
The only reason i would see not to use a shim kit is if you are planning to readjust your camber. I like my camber to be exactly the same on both sides so I want it to be dialed in correct to my specific settings at the alignment machine. If you just want to lower the camber to closest to zero, then the shim kit is much better if you have less than 1.5 degrees of camber.
Old Dec 1, 2005 | 12:48 AM
tkycgo's Avatar
I have bought omni rear shim kit..... and skunk2 front camber kit....
Now I am considering about the lowering springs......
Which is good for my car with oem shocks? eibach, h&r or tanabe or.......
Old Dec 1, 2005 | 12:52 AM
tkycgo's Avatar
Default Re: (Danronian)
why I need to serious about the rear camber kit. It's because if I drive my car to make a alignment, I need to spend money, why not adjust the front and rear? If I install front camber kit only and make a alignment, It's same price, right?
Old Dec 1, 2005 | 01:18 AM
Ches's Avatar
washers worked for me
Old Dec 1, 2005 | 01:40 AM
tkycgo's Avatar
Default Re: (AP1_BoY)
I found out now lowering eating rear tires not much, but front tires are eating inside so much.
Old Dec 1, 2005 | 03:06 AM
bad toe will wear your tires out faster than camber will ever do.
If you are really worried about tires, front camber kit and rear shim kit will work wonders for you. Just make sure to go to an alignment shop that will do camber kit adjustments too.
dc4_wHORE
Oct 19, 2010 05:48 PM
matt94z
19
Aug 8, 2008 06:14 AM
DualCamDan
72
Sep 8, 2005 11:13 AM
NW94RS
Dec 24, 2003 03:16 AM
brian2903
Nov 13, 2003 10:35 PM
