Stock OEM 1990 DX 13" Steelies on 1993 Civic Si Coupe???
I need to know if a stock Honda OEM 13" steel rim from a 1990 DX will fit on my 1993 Civic Si Coupe. I know the back should fit, but my concern is the front clearance with the large rotors and calipers.
I was told that the Si "Hatchback" rotors are 9.5", and that the 13" wheel fits.
Apparently the rotors on Civic Si Coupe's are 10.3", not letting the 13" steel rims to fit.
Does anybody know For sure? I need to know ASAP. Thanks
hum i have 90 ls integra brakes (same pads for the si dont know if the caliper is the same)on my ef, the stock 13 dont clear, only 14 clears, dont know if that helps
Hmm, will i at least be able to get the rim on enough to be able to thread the nuts on, or does it not fit on at all? The car won't be driven on, just parked in my storage area. Thanks
it doesnt fit at all even with the 14" rims, it barrrely clears by a **** hair
storage? just throw the rim under the car, and put the car down on the rim, or use jack stands
hamilton_civic
Mar 19, 2008 03:36 PM
RedheadRacing
16
Jan 30, 2004 12:12 PM
