Eliminating coolant lines on a BLOX intake manifold
Old Nov 26, 2005 | 09:08 PM
CRX_1.8T's Avatar
Default Eliminating coolant lines on a BLOX intake manifold
Hey brothers, to make a long story short... I am getting rid of any non-essential coolant lines on my BLOX intake manifold and capping off the various nipples on it. I bought this manifold brand new and for whatever reason, it gets coolant into the intake. The problem is not the gaskets, we have quadruple-checked that already and even got new ones. Still have not fixed it...
The engine is a OBD-0 B18A.
My question is, which coolant lines are crucial and which ones can I live without? I looped the IACV but am not too sure of what exactly to do at this point. I am just trying to figure out how the coolant is getting into my intake manifold, and am hoping this will help narow it down.
Thanks guys.
Old Nov 27, 2005 | 06:18 AM
CRX_1.8T's Avatar
Default Re: Eliminating coolant lines on a BLOX intake manifold (CRX_1.8T)
bump ^
Old Nov 27, 2005 | 07:54 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
bump
Old Nov 27, 2005 | 02:32 PM
CRX_1.8T's Avatar
Default Re: (^^whatnoobsearchthenGTFO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^^whatnoobsearchthenGTFO &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Thanks man.
bump
Old Nov 27, 2005 | 03:30 PM
CRX_1.8T's Avatar
Default Re: (CRX_1.8T)
Does anyone know if any coolant lines need to be run through my intake manifold at all? If I can get rid of all of the lines going through the intake manifold into my head, that would be ideal.
Old Nov 27, 2005 | 06:21 PM
elrandeeto's Avatar
bump bc i have the same problem , never got a answer so i put the stock back on .
i know exactly what your talking about .
just to make his problem more clear here is a pic
the bottom right corner of the pic the nipple on the flange with the big while and the little one below it ( they go to the same whole in the block .
on the stock manifold there is a big one then a small one to the right of it for coolant they go to different holes in the block
when you put the blox on , the flange covers the coolant hole and only utilizes one of the wholes in the block whick i think has to do with pcv system , but the nipple has two opening and you dont want to mix coolant with that
so what do we do
Old Nov 27, 2005 | 07:53 PM
elrandeeto's Avatar
Default Re: (elrandeeto)
that coolant line going to the head , im pretty sure u have to use it
Old Nov 27, 2005 | 07:56 PM
CRX_1.8T's Avatar
The big hose that comes off of the thermostat?
Old Nov 27, 2005 | 08:17 PM
elrandeeto's Avatar
is that what it is i wasnt sure , its the only big hose in that area other then the coolant line
Old Nov 28, 2005 | 09:56 AM
elrandeeto's Avatar
bump
Old Nov 28, 2005 | 06:37 PM
CRX_1.8T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elrandeeto &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Old Nov 28, 2005 | 07:00 PM
Trooper's Avatar
it is EXTREMLY important that you run the coolant hose from the thermostat through the manifold. I have two friends burn up#3 cylinders because they didnt run that hose. other than that you can block every thing off.
Old Nov 28, 2005 | 07:31 PM
CRX_1.8T's Avatar
Default Re: (Trooper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trooper &raquo;</TD></TR><TR><TD CLASS="quote">it is EXTREMLY important that you run the coolant hose from the thermostat through the manifold. I have two friends burn up#3 cylinders because they didnt run that hose. other than that you can block every thing off. </TD></TR></TABLE>
Thank you.
Old Nov 28, 2005 | 09:58 PM
elrandeeto's Avatar
ya but that c oolant line (the smaller hose , doesnt go into the same whole with blox intake ,
it mixes with whatevre the bigger hose is for
Old Nov 29, 2005 | 01:55 PM
CRX_1.8T's Avatar
Does anyone know if those coolant lines are mixing with the PCV?
Old Nov 29, 2005 | 07:47 PM
CRX_1.8T's Avatar
Ok I just put 20 miles on my CRX without a hint of smoke.
I eliminated all of the throttle body and IACV lines, but that's it. I looped the IACV since it doesn't get cold here. I capped off all of the nipples related to the IACV and throttle body.
I also replaced my PCV since it was surging in idle, and that fixed it. It doesn't overheat either, which is nice for a change.
My CRX is running once again.
holmesnmanny
Jun 9, 2012 11:33 AM
1337 Si
Mar 24, 2005 09:26 AM
Tuney
Feb 26, 2003 07:19 PM
