Do OBD0 and OBD1 map sensors read different voltage?
Old Nov 26, 2005 | 03:23 PM
Cloner's Avatar
Default Do OBD0 and OBD1 map sensors read different voltage?
I converted my crx(b16) from obd0 to obd1. Im using a p28 ecu which I burned a stock del sol program for it. The car revs fine all the way up. But when I drive it and floor it cuts out at 3000rpms. I cant figure it out other than Im using a stock crx si map sensor. Are the obd0 and obd1 map sensors different? I have an obd1 map sensor but I dont wanna put it on without knowing for sure.
Old Nov 26, 2005 | 06:15 PM
Tbone's Avatar
Default Re: Do OBD0 and OBD1 map sensors read different voltage? (Cloner)
Nope the maps sensors read the same.
Old Nov 26, 2005 | 06:16 PM
Tbone's Avatar
Default Re: Do OBD0 and OBD1 map sensors read different voltage? (Tbone)
Usually when you hit a 3000 revlimit it mean the your burn to the chip failed and its running in failsafe mode.
Old Nov 26, 2005 | 09:24 PM
Cloner's Avatar
Yeah but why does it let me rev to 9000rpms.Its only under load that it cuts out.
bswappedej1
Oct 21, 2011 09:32 PM
dek1mfk
Nov 7, 2006 07:39 AM
SVOboy
May 22, 2006 03:42 PM
SiMateoAko
Mar 23, 2006 08:22 PM
