my first motor swap, what am i forgetting
Old Nov 26, 2005 | 02:42 PM
jadugartir's Avatar
Default my first motor swap, what am i forgetting
Im swapping a obd2 b-series, so first i took out my old engine harness and dizzy because my friend is going to wire it up.
Then i took out the axles.
then shift linkage
then i drained all the fluids
im now ready to undo all the mounts and drop it correct?
Old Nov 26, 2005 | 02:49 PM
crackerjacker006's Avatar
Default Re: my first motor swap, what am i forgetting (jadugartir)
dude there is a million write ups on this please search a little. The best place to find step by step procedure is... i think cspeedracing.com they have a how to put a b18c into an eg. As for your question, yes if everything is unhooked you can loosen the engine mounts just make sure you unhook everything and attach it to an engine hoist.
Old Nov 26, 2005 | 02:51 PM
jadugartir's Avatar
Default Re: my first motor swap, what am i forgetting (carjacker006)
thanks for link
Old Nov 26, 2005 | 02:58 PM
transpar_nt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jadugartir &raquo;</TD></TR><TR><TD CLASS="quote">Im swapping a obd2 b-series, so first i took out my old engine harness and dizzy because my friend is going to wire it up.
then shift linkage
im now ready to undo all the mounts and drop it correct?</TD></TR></TABLE>
Why don't you just look in the engine bay? Everything that connects the engine to the car obviously needs to be removed.
-disconnect vacuum lines
-disconnect coolant hoses
-unbolt compressor from block (if applicable)
-unbolt ps pump from block (if applicable)
-disconnect throttle cable
-disconnect clutch
-unbolt header from cat
-disconnect fuel line from filter housing
-disconnect cruise control (if applicable)
-use the search function (very applicable)
Jdmefsir12
Mar 29, 2008 11:19 AM
924doorEG
Feb 17, 2008 12:45 AM
frankboy1269
Oct 30, 2006 08:51 PM
West Werks
Aug 15, 2005 07:20 AM
Awar318
Mar 29, 2004 08:20 PM
