WTH Happened? Looks like my Coil exploded!
Old Nov 26, 2005 | 01:30 PM
Jose-aka-Pedro's Avatar
Default WTH Happened? Looks like my Coil exploded!
Hey guys,
My car is a 90 integra rs B18A1 obd0
So here is what happened
I went out to a friends house for the day, drove around alot,
Well, Last night I came home. Got some stuff together and was ready to go cruise
So I get out of my driveway, shift into second, and then I shift into third
Give gas and nothing, I was like, HUH? Because normally it goes faster when I give it gas So I tried to give it gas again and nothing,
It just died right there, Tried to start it, nothing, tried to jump start it nothing,
Tried to pp it into gear and start it nothing
Well, I went today and got the battery tested its perfect.
So after searching
I went out to look at the coil, ignitor, starter all that good stuff
So I took off the cap and found this :SHOCK:
So, What Happened?
What All Do I Need?
Coil, Cap, Rotor. Do I need a full obd0 dizzy?
Thanks, Later
Old Nov 26, 2005 | 01:33 PM
89 pos's Avatar
Default Re: WTH Happened? Looks like my Coil exploded! (90DA9IntegraRS)
damn
Old Nov 26, 2005 | 01:40 PM
89 pos's Avatar
Default Re: WTH Happened? Looks like my Coil exploded! (89 pos)
i had to replace the cap on my rex becouse the part that goes into the coil was burnt off it sucked
Old Nov 26, 2005 | 01:48 PM
Thurman Merman's Avatar
Time to start looking for a new distributor bub. While you're at it, when you've got the dizzy off, i would remove the valve cover just to take a look at the intake cam or inside to make sure everything is copasetic.
Old Nov 26, 2005 | 02:14 PM
IntegraJdmb18c1's Avatar
Default Re: WTH Happened? Looks like my Coil exploded! (Thurman_Merman)
WOW sorry to hear that new disturbator would be great but dont just fix it try to see what casued it as well so you dont end up with the same problem in the long run check your coil make sure that isnt sending out more voltage then the distubator can handle might be that
Old Nov 26, 2005 | 02:20 PM
Platinum Playa's Avatar
Dam, wtf when i saw the first pic i buss out laughing. Contact distributor king a vendor on our site...sweet prices great quality and overnight shipping!
Old Nov 26, 2005 | 02:27 PM
Default Re: (Platinum Playa)
so its not just an coil huh....
Well, This sucks,
Old Nov 26, 2005 | 02:33 PM
89 pos's Avatar
Default Re: (90DA9IntegraRS)
i got my dizzy for my 92 teggy from the king for cheap look them up on ebay thats how i got mine it works great only gave around 150 for it
Old Nov 26, 2005 | 03:02 PM
Default Re: (89 pos)
lol, I dont have 150, I dont even have 100,
Could I get by for tonight with a new coil, cap and rotor?
Old Nov 26, 2005 | 03:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90DA9IntegraRS &raquo;</TD></TR><TR><TD CLASS="quote">
Ok... No one wants to help?
Old Nov 26, 2005 | 03:33 PM
Old Nov 26, 2005 | 04:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90DA9IntegraRS &raquo;</TD></TR><TR><TD CLASS="quote">Ok... No one wants to help?</TD></TR></TABLE>
like i said, time for a new distributor.
and no, you can't get by tonigth with new cap, rotor, and coil lol. don't be lazy and cheap out, do it the right way and get a new dizzy.
Old Nov 26, 2005 | 04:52 PM
92integraVTECgsr's Avatar
YA.. why would you waste your money (50-75 bucks) on all that and have it do it again.. find out the problem. people who do things "just to get by" end up spending more in the long run. save time and money and do it right the first time.
Old Nov 26, 2005 | 05:41 PM
KooK's Avatar
Mustang Sally
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Platinum Playa &raquo;</TD></TR><TR><TD CLASS="quote">Dam, wtf when i saw the first pic i buss out laughing. Contact distributor king a vendor on our site...sweet prices great quality and overnight shipping!</TD></TR></TABLE>
Oddly enough, I started laughing also. I saw that picture and its like, whoa, what the hell!
Congrats though, I think you just topped my personal list of weird problems.
Old Nov 26, 2005 | 09:53 PM
Default Re: (KooK)
New coil, cap and rotor and she runs like new.
I have no choice, I couldnt offord a new dizzy.
This will get me by for the next week or so.
Thanks for your help guys. Later
I'm not that worried about the engine as It is getting replaced in the spring by an Imported Built B18A for boost (hope summer)
Old Nov 27, 2005 | 01:14 AM
Naruto's Avatar
Spring is months away.....you risk having the car die on you again. If I were you....I'd find a way to afford a dizzy.....
you don't want to be in the midst of traffic for this problem to repeat itself. *knock on wood*
Old Nov 27, 2005 | 02:20 AM
ITB
Guest
Posts: n/a
distributor king can give you a complete dizzy for 150 shipped. some people praise them and others say they suck. so i dont know
Old Nov 27, 2005 | 05:37 AM
91civicDXdude's Avatar
you guys sure keep distributor king's pockets full... "my ignitor went bad, time to buy a new distributor"
replace the broken part and save a boatload of cash.
Old Nov 27, 2005 | 06:49 AM
SJP0tato's Avatar
My guess as to the cause would either be a mis-aligned distributor cap (causes the little coil node on the spring to bind within the little shaft in the coil) or distributor cap failure of some type (sometimes the little node on the end of the spring in the cap can detach).
In either case, an increased gap between the coil and the distributor cap node causes the current to have to "jump" the gap between the coil and cap. Each time the electricity is forced to take this random jumped path corrosion and heat can result. Repeat this 100,000 times or so, and you get a ton of that white oxidation stuff and melted plastic components.
You're probably going to be fine with the new coil and distributor cap, although I'd recommend opening it up in a week or so and checking out the contacts. If you see any more of that white oxidation looking stuff on the new components then it's happening again.
Good luck!
Old Nov 27, 2005 | 08:02 AM
ricebucket's Avatar
Default Re: WTH Happened? Looks like my Coil exploded! (SJP0tato)
This is funny, with people keep teling you to get new dizzy.
"Hey I got a flat tire what should I do?"
"Dude that sucks, you are going to need a new rim and 4 lug nuts, but meh I would get all 4 new tires and rims just so it's perfectly balanced."
You did perfect with just getting a new coil, cap and rotor. I would have gone with an external coil myself since its cheaper and suposedly a bit stronger.
Old Nov 27, 2005 | 09:02 AM
Default Re: WTH Happened? Looks like my Coil exploded! (ricebucket)
thats what I'm doing, in a week, Buying the MSD Cap W/external coil, rator etc...
along with a new dizzy
Old Nov 27, 2005 | 09:14 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90DA9IntegraRS &raquo;</TD></TR><TR><TD CLASS="quote">thats what I'm doing, in a week, Buying the MSD Cap W/external coil, rator etc...
along with a new dizzy</TD></TR></TABLE>
---&gt; its *rotor*
JDM-DA
Engine Management and Tuning
Apr 15, 2010 10:41 AM
Th3savinday
Feb 19, 2008 09:52 PM
JDM-EJ1
Aug 22, 2005 04:39 AM
POWERINTEGRA
Nov 7, 2004 11:30 AM
04accordV6
Jul 31, 2002 11:53 PM
