h22a h22a1 water pump
Pumps are the same, i have a jdm h22a and installed a usdm new h22a1 pump.
Jdm h22a= internal coil dizzy, no ect switch B, no air boost valve( i think thats what its called)
yes you can use the usdm dizzy and external coil, no need to swap intake manifolds, use your usdm h22 fuel rail with jdm h22 injectors/fuel pressure regulator. You can even swap your usdm h22's upper radiator housing( right above engine stamp/ houses the ect switch B) im using my f22's housing with switch B. Also use your usdm engine wiring harness
tegman85
May 23, 2007 05:59 PM
