Blower motor ???? please help Searched for days and nothing
ok a few days back a did a search about blower motors not working so from what i read the blower was bad so i replaced it today and still nothing i check the fuse for the third time and it looks good so my question is is there anything else that im missing as of what to check keep i mind that i allready replaced the motor from a donor car witch was working when i pulled it off any help please
UNPLUG THE PLUG IN THE MOTOR AND TEST FOR POWER WITH THE SWITCH IN ALL POSITIONS IT SHOULD GO UP WITH EACH NUMBER IF THERE IS PWR THE MOTOR IS BAD BUT IF NOT CHECK YOUR SWITCH MINE IS BAD NOW AND I GOT TO CHANGE SOON..ITS COLD HERE IN CT
there should be a big 6 pin plug behind your heater controlls one wire is gnd and one is pwr and the other 4 are outputs if there is pwr and gnd then your switch is toast
if there isnt pwr or gnd then that is the prob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88cerx »</TD></TR><TR><TD CLASS="quote">there should be a big 6 pin plug behind your heater controlls one wire is gnd and one is pwr and the other 4 are outputs if there is pwr and gnd then your switch is toast
if there isnt pwr or gnd then that is the prob</TD></TR></TABLE>
well i check the plug and ther is no pwr or grnd so i check the fuse one more time and its good why im not getting power to ther if my fuse is good?
if there isnt pwr or gnd then that is the prob</TD></TR></TABLE>well i check the plug and ther is no pwr or grnd so i check the fuse one more time and its good why im not getting power to ther if my fuse is good?
well that's what i thoght that there is a relay in between the conector to the switch and the fuse but i don't see any
well found out what was wrong with my blower the reason why it didn't work is cuz my ignition switch was bad LOL it took me like 4 hrs to find out the problem and fix it
voodooutt
Dec 24, 2007 09:08 PM
