buying a legit gsr motor, but one problem, need help
Old Nov 26, 2005 | 10:48 AM
D15Bbigred's Avatar
Default buying a legit gsr motor, but one problem, need help
well it has motor, trans, ecu. its a 97 with 70,000 miles. problem the car caught on fire, but was put out before it harmed the motor. any steps of precaution i should take before i purchase this motor???
Old Nov 26, 2005 | 11:17 AM
del_slow420's Avatar
Default Re: buying a legit gsr motor, but one problem, need help (EJ1D16Z6)
u might want to check ur vacum lines and all wiring just to be safe and make sure nothing is shorted out..and u can replace grounds...
Old Nov 26, 2005 | 11:19 AM
Jay_Sensing's Avatar
Wiring will be the biggest deal. Anything else should be easy to fix if there is no visible damage but a burnt harness is a major PITA to repair and not cheap to replace. If everything up to the three large connectors on the passenger shock tower are ok, I wouldn't worry about it too much.
Old Nov 26, 2005 | 01:44 PM
D15Bbigred's Avatar
wiring harness is not an issue, its going in my 93 ex coupe, and i believe you can use some of that wiring, with the p28. what about oil seals??
Old Nov 26, 2005 | 04:33 PM
D15Bbigred's Avatar
Default Re: (EJ1D16Z6)
^^up for the night owls
chocolatesk8er10
Mar 6, 2008 06:21 AM
Roca fella Bryan
Jun 9, 2007 08:14 PM
H22ACiViC
Dec 23, 2001 11:22 PM
