Suspension & Brakes Theory, alignment, spring rates....
Suspension help plzzz
Old Nov 26, 2005 | 10:38 AM
pbzhb's Avatar
Default Suspension help plzzz
Hey im thinking of doing an H22 swap and was recommended omni coilovers or nex coilovers. Im not to sure which ones to get or if i should get even another company. ALso how do I know which schocks work with which coilover system im confused plz if some1 can clarify and recommend. thanks
Old Nov 27, 2005 | 02:47 PM
.RJ's Avatar
.RJ
Default Re: Suspension help plzzz (pbzhb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pbzhb &raquo;</TD></TR><TR><TD CLASS="quote"> im confused </TD></TR></TABLE>
Clearly.
Search this forum, and the road race forum archives - tons of good info if you would take the time to read through it.
Old Dec 1, 2005 | 10:34 AM
bmoua's Avatar
what kind of ride do you want though?? stiff as hell go with the omnis...there really stiff but the ride isn't too great...im not sure about the other coiloves you metioned...
Old Dec 1, 2005 | 10:46 AM
.RJ's Avatar
.RJ
Default Re: (bmoua)
Stiff doesnt always mean good handling either.
Old Dec 1, 2005 | 12:02 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (.RJ)
Stick with the quality of Ground Control coil-overs. They know their stuff. If you order directly from them, you can tell them what chassis you have & what motor swap, and they put a custom kit together for you with special spring rates for your setup.
Any other brand would be a crap shoot...
Also, try to decide what shocks you want to use before you buy the Ground Controls. They are the only company that makes the specialized sleeves that fit Koni & Bilsteine shocks.
Old Dec 3, 2005 | 10:44 PM
bmoua's Avatar
Default Re: (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">Stick with the quality of Ground Control coil-overs. They know their stuff. If you order directly from them, you can tell them what chassis you have & what motor swap, and they put a custom kit together for you with special spring rates for your setup.
Also, try to decide what shocks you want to use before you buy the Ground Controls. They are the only company that makes the specialized sleeves that fit Koni & Bilsteine shocks.</TD></TR></TABLE>
i agree with this guy...i had the omnis full coils 6 way adj...didnt like them..rode like ****...just installed some GC's with kyb adj ....man..it rides 10x better....
UndisputedH22a
24
Nov 3, 2009 08:47 AM
mmvito
Feb 11, 2008 05:30 AM
kornerk12
Apr 12, 2006 06:55 PM
tlclee
Honda S2000
57
Feb 18, 2005 06:10 AM
