Engine alignment in engine bay, engine mount related....
Old Nov 26, 2005 | 08:39 AM
80884's Avatar
Default Engine alignment in engine bay, engine mount related....
Ok this might seem like a weird question. With the engine and trans mounted in the car, front wheels off and no axles (cuz i don't have them yet). Do the outlet of the transmission where the axles hook into, also on the intermediate shaft end, are they suposed to be farther to the front of the car than where the spindle hole is for the axles? Reason I am asking is I bought avid mounts and when i tried to put them in I had problems with the driver side mount lining up right. I had to drill holes in the bracket that came with the kit for it to bolt up right. But when i did this i didn't realize that this actually moved the drivers side of the engine to the front of the car, also pointing the driver side axle to the front more than the pass side. I'm thinking that one of the other mounts isn't right and it is causing this one to be off.
I just wanted to see how the axles were suposed to be once the engine is mounted. I switched the driver side mount back to the stock mount and mounted it first, this seamed to have moved the engine back to where it should be. Both axle outputs are pointing to the side of the car, they are just farther forward in the car than where the spindle holes are about 1-2", is this normal? here is a pick of my drilled motor mount.
Old Nov 26, 2005 | 09:54 AM
SlowReaction's Avatar
Default Re: Engine alignment in engine bay, engine mount related.... (80884)
If thats the avid kit then thats why. I installed the same exact one *jdm b16 in a ek hatch* and it was all messed up.
Old Nov 26, 2005 | 10:56 AM
80884's Avatar
Default Re: Engine alignment in engine bay, engine mount related.... (SlowReaction)
Yep avid kit, pain in the *** to get engine in and it doesn't line up right, with stock mounts it falls into place. I changed the driver side mount back to the stock one and it seamed to work out better but i have no idea if it's where it needs to be.
Old Nov 27, 2005 | 05:46 PM
80884's Avatar
Anyone have a pic showing transmission to hub alignment? Like a pic of axle when your standing by the hub? ahh hard to explain. I'll take pics as soon as i get new batteries, prob tomorrow night.
Civic168
Suspension & Brakes
Feb 28, 2006 09:21 PM
marc-111
Jan 25, 2006 11:37 PM
2000DX
Jun 23, 2004 11:15 PM
