Raspy buzz around 3000 RPM...?
Old Nov 26, 2005 | 07:42 AM
P@@RB@Y's Avatar
Default Raspy buzz around 3000 RPM...?
I just bought a 95' GSR.Mods are Injen intake and a ITR intake cam.Everything else is stock.
Around 3000-3300 RPM theres a raspy buzz sound.I thought it might be the intake but Im not to sure.Anybody else have this?
Old Nov 26, 2005 | 01:21 PM
P@@RB@Y's Avatar
Default Re: Raspy buzz around 3000 RPM...? (P@@RB@Y)
Bump
Old Nov 26, 2005 | 01:24 PM
Johnny_Rocket's Avatar
check your head shields on the exaust, especially the cat
Default Re: Raspy buzz around 3000 RPM...? (JohnnyH)
Or it could be a shitty muffler now that I think of it
Old Nov 26, 2005 | 02:08 PM
Azn Kenny's Avatar
Do you have a test pipe?
Check for any exhaust leaks too, may be a gasket.
Old Nov 26, 2005 | 02:19 PM
P@@RB@Y's Avatar
Default Re: (kennyfsu)
As far as I know there exhaust is tock and never had a header or anything put on.Ill look for any loose bolts...
Old Nov 26, 2005 | 04:28 PM
sooo_slow's Avatar
New User
Default Re: (P@@RB@Y)
Is there a resonator? b/c I've heard that exhausts can sound like bumble bee's without them.
Old Nov 26, 2005 | 05:24 PM
toygsr's Avatar
Check your header. It is double walled, and the weld that holds the piping prob. broke loose. It is a common problem on the GSR models. I had the same thing and ended up replacing my header with a comptech one. No problems since.
Good Luck.
Will
Old Nov 26, 2005 | 06:38 PM
P@@RB@Y's Avatar
Default Re: Raspy buzz around 3000 RPM...? (toygsr)
Im ignorant...Double walled?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toygsr &raquo;</TD></TR><TR><TD CLASS="quote">Check your header. It is double walled, and the weld that holds the piping prob. broke loose. It is a common problem on the GSR models. I had the same thing and ended up replacing my header with a comptech one. No problems since.
Good Luck.
Will </TD></TR></TABLE>
Thanks
Old Nov 26, 2005 | 07:34 PM
Integra_drk's Avatar
is it all the time or just during the first 5 min or so after start up?
Old Nov 26, 2005 | 07:49 PM
P@@RB@Y's Avatar
Default Re: Raspy buzz around 3000 RPM...? (Integra_drk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra_drk &raquo;</TD></TR><TR><TD CLASS="quote">is it all the time or just during the first 5 min or so after start up?</TD></TR></TABLE>
All the time in every gear around 3000 RPM.If I hold the throttle around 3000 RPM it just keeps buzzing.It sounds like what a cheap exhaust would sounds like but its not?
Im gonna check the manifold tommorow.
Old Nov 26, 2005 | 08:35 PM
hmm mine used to do that for the first few minutes before i got my exhaust. id check the heat shields and if you are getting an exhaust in the future that might take care of it.
Old Nov 26, 2005 | 10:02 PM
98b18black's Avatar
Yeah...I would say one of the heat shields...I had the same problem...
Old Nov 27, 2005 | 03:03 AM
MoToWnSBaLLa's Avatar
yea i have a 96 gsr and around 3k rpms it rattles...theres a sheild on ur cat or around there that keeps hitting..i think i got mine taken off now it doesnt do it anymore
Old Nov 27, 2005 | 07:35 AM
Train's Avatar
Good Luck.
yeah, GSRs have this problem. what he means by "double walled" is ... where the two secondaries merge into the collector, the secondaries' collector slips over the visible collector, like a male and female type fit. if you use your hands to understand, make a "C" with one hand and a slightly larger "C" with the other. then put one hand inside the other. thats how the collector and secondaries fit together. it's double walled there. one of the welds broke loose, so those two pieces are vibrating. thats your buzzing sound. you need a new header. fixing the problem would require more work than necessary.
EDIT: when i swapped my header out for this problem, it should have taken off my heat shields too, cause a few days later i got another rattling sound. it was a noticably different sound than the header buzz, but while you're swapping out the header, you might as well remove the heat sheilds while you're under the car.
Old Nov 27, 2005 | 07:47 AM
P@@RB@Y's Avatar
Default Re: Raspy buzz around 3000 RPM...? (Train)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Train &raquo;</TD></TR><TR><TD CLASS="quote">
EDIT: when i swapped my header out for this problem, it should have taken off my heat shields too, cause a few days later i got another rattling sound. it was a noticably different sound than the header buzz, but while you're swapping out the header, you might as well remove the heat sheilds while you're under the car.</TD></TR></TABLE>
Thanks alot, I understand now.Heatshield around the cat right?
j0nathanl3e
Jul 8, 2005 12:00 PM
SpeedMachine
May 7, 2005 04:04 PM
ynotlim
Oct 2, 2004 09:12 PM
JforJonathan
16
May 3, 2004 06:54 PM
TakaIntegra
Jun 17, 2002 08:31 PM
