help! clifford alarm acting up, car wont start, need to move asap!!! help!!
Old Nov 26, 2005 | 02:15 AM
oh-k's Avatar
Default help! clifford alarm acting up, car wont start, need to move asap!!! help!!
my car is stranded in another city, and in a no parking zone..
have a clifford alarm. when i put the key in and turn twice, no light on t he cluster turn on. however all lights/radio works. i believe it is my kill switch. how can i disable the alarm or disable the kill switch. i have tried removing brain, fuses, taking battery off.. please help... how can i atleast start my car???
Old Nov 26, 2005 | 08:05 AM
fcm's Avatar
fcm
Old Fart
Default Re: help! clifford alarm acting up, car wont start, need to move asap!!! help!! (oh-k)
What Clifford alarm? Need to know, so I can look it up and see if "kill" relay is on or off board.
If relay is off board, you need to find relay, unplug it and install jumper wire, if relay is on board then you can make the jump at the plug at the alarm. 94
Old Nov 26, 2005 | 11:05 AM
oh-k's Avatar
Default Re: help! clifford alarm acting up, car wont start, need to move asap!!! help!! (fcm)
think its a g4
Old Nov 27, 2005 | 06:56 AM
fcm's Avatar
fcm
Old Fart
I need a model number, G4 is the series.
It sounds like it is a "built in" immobilizer, you probably have a "2 point" starter and ign. or a "1 point" and it has been wired to the ign.
Without model number I am just guessing, but if you have a 3 pin plug, [heavy gauge wire, plugged into brain] and it has , [green/white, green and a green/black] wires in it, [the green/black may have been removed] as I believe the immobilizer was wired, [normally open] because you don't get ign. even when alarm brain is unplugged.
If you have that plug with the heavy gauge wire, connect the, [green/white and green together]
Your alarm may not have the colored wires, just 1 or 2 sets of black heavy gauge wires, if its just one set, no biggy, connect them together, if its 2 sets, 1 set will be the ign. kill and the other will be the starter kill, you will have to figure out what is what, you can do that by following the wires back to the connections to the oem wiring, [I can't tell you what color they are until I know the MMY of car]
Old Nov 28, 2005 | 09:24 AM
oh-k's Avatar
ty, it was a faulty wire from starter to a kill switch wire
jdmaccorn
Audio / Security / Video
Sep 17, 2009 04:11 PM
Project.Jdm
May 22, 2008 04:19 PM
type B16
Jan 8, 2007 04:49 PM
Se-rv-Tak
Jan 22, 2004 09:18 AM
