EK Wont Start Starter problem? HELP HELP HELP!!!!
Old Nov 25, 2005 | 11:37 PM
civicguy167's Avatar
Default EK Wont Start Starter problem? HELP HELP HELP!!!!
I pulled my car in my garage and the next morning i turned the key, everything lit up, fuel pump primed. But it wouldnt start, no clicks, no noises, doesnt turn over.
Ive already:
Replaced starter
changed starter signal fuse
triple checked connections
The car starts and runs fine if a push start it.
Please someone help i gotta get this fixed!!!
Old Nov 26, 2005 | 12:36 AM
Eaglekper0046's Avatar
Default Re: EK Wont Start Starter problem? HELP HELP HELP!!!! (civicguy167)
Check your grounds to the motor. My buddies ls had the same problem one of his grounds wasn't tight. For some reason hondas are real bitchy when its comes to grounds. Talk nice to her.lol
Old Nov 26, 2005 | 12:52 AM
Default Re: EK Wont Start Starter problem? HELP HELP HELP!!!! (Eaglekper0046)
just rechecked grounds and they are all tight
Old Nov 26, 2005 | 08:33 AM
up
Old Nov 26, 2005 | 09:12 AM
nub's Avatar
nub
could be a bad ignition switch, have you checked to see if you are getting starter signal at the starter when trying to crank
Old Nov 26, 2005 | 09:15 AM
No, how do i do that? just use a 12v tester on the plug (the one w/ the rubber boot) when cranking? Where is the ignition switch located?
Old Nov 26, 2005 | 09:28 AM
nub's Avatar
nub
Default Re: (civicguy167)
yea you can put your test light on the signal wire of the starter (the one with the boot) and have a friend crank or try to crank while you watch. the ignition switch is where you put your key to start your car, to check it you need to drop your dash and find the harness comming from the key switch open it up and find the black wire w/ white stripe, same, probe wire with test light while trying to crank. just a thought if manual trans could be the clutch switch on the pedal
Old Nov 26, 2005 | 09:30 AM
saywhat's Avatar
try giving the starter a light couple of taps with a hammer and see if the solenoid seized, worth a try!
efhondaracer27
Jan 21, 2010 10:32 AM
battleREADYb20
Apr 30, 2009 02:36 AM
reelhybrid
Feb 1, 2007 03:05 PM
dizzyroc88
Nov 17, 2005 08:22 AM
4play4dr
Nov 16, 2005 02:47 PM
