D15B7 Compression Test Specs
Old Nov 25, 2005 | 07:44 PM
MKIIISupra's Avatar
Default D15B7 Compression Test Specs
I am doing a compression test on my '93 D15B7. I was wondering what the specs are for it.
Thanks
Old Nov 25, 2005 | 07:55 PM
my_slow_civic's Avatar
Default Re: D15B7 Compression Test Specs (MKIIISupra)
Check compression with engine at normal operating temperature and throttle in wide open position. Prior to performing test, disable ignition and fuel injection to prevent fuel from being sprayed into cylinders while cranking engine. Ensure the battery is fully charged and that cranking speed is 250 RPM. Standard reading should be 135-184 psi. The maximum variation between cylinders is 28 psi.
Old Nov 25, 2005 | 08:05 PM
MKIIISupra's Avatar
Default Re: D15B7 Compression Test Specs (my_slow_civic)
Thanks
Old Nov 6, 2013 | 04:23 PM
JMOWMONEY's Avatar
Really only 135-184?? I am doing a compression test on my d15b7 also. Because this car is soooooo slow! I punch it and it goes no wheres. Lol but im gonna try doing a comp. Test..... gotta start somewheres....
Old Nov 6, 2013 | 05:39 PM
24TEN's Avatar
PHANTOM MENACE
In the future, unless you are contributing something worthwhile to an old thread you should skip it (especially an 8 year old thread).
76 camaro car
Apr 20, 2017 04:47 AM
liquidzorch
Sep 13, 2013 07:33 PM
crazyhouse2011
Mar 18, 2013 07:50 PM
1320ms
Sep 3, 2007 01:31 PM
GODSPEED33
Dec 22, 2006 06:04 AM
