intake manifold question
i just swapped a new jdm b18b into my 95 teg and with the motor came a new model of intake manifold. my old one was a HF-2 and this new one is a HF-3. one of the differences on the manifold is an extra hose outlet at the base on the TB side. and now im not sure what hose to hook up to the spot just under the TB inlet. should i block the new hose on the manifold or should i block the old hose with nothing to hook into? or am i missing something that the new hose should be hooking into instead? both pipes are routing coolant by the way. heres a few pics to help visualize the issue at hand. thanks in advance.
new outlet
the new coolant hose
the old coolant hose (other end hooks up just under the upper radiator hose)
new outlet
Yuta
Jun 24, 2019 05:06 PM
Semper_WiFi
Jun 22, 2009 12:01 PM
