ITR LSD direct fit into a YS1 (92-93gsr) Transmission???
Old Nov 25, 2005 | 07:23 PM
92integraVTECgsr's Avatar
Default ITR LSD direct fit into a YS1 (92-93gsr) Transmission???
would an ITR LSD direct fit into a YS1 (92-93gsr) Transmission???
Old Nov 25, 2005 | 08:22 PM
Default Re: ITR LSD direct fit into a YS1 (92-93gsr) Transmission??? (92integraVTECgsr)
bump
Old Nov 25, 2005 | 08:36 PM
b17aprincess's Avatar
Default Re: ITR LSD direct fit into a YS1 (92integraVTECgsr)
maybe... but how much you selling your gsr for?
Old Nov 25, 2005 | 08:37 PM
Default Re: ITR LSD direct fit into a YS1 (b17aprincess)
i hoping for around $4500, but i got a kid wanting me to make a deal with him if i take the rims off.
so probably around $4000 now.
Old Nov 26, 2005 | 08:44 AM
randygzrs's Avatar
See if you can find someone online with an LSD b16 cable tranny. Synchros are impossible to find for this tranny so there are a lot of people who have it just sitting around. Maybe they will sell the LSD itself. I was able to put this LSD in my 92 LS cable tranny. Just remember to have them also send the spacers. Otherwise there will be too much play on the LSD from side to side.
Old Nov 28, 2005 | 01:45 PM
anyone else?
looking for a LSD for my YS1 Transmission (92gsr)
Old Nov 28, 2005 | 01:50 PM
YumVTEC's Avatar
kaaz? quaife? phantom grip?
Old Nov 28, 2005 | 01:51 PM
Default Re: ITR LSD direct fit into a YS1 (YumVTEC)
how are the phantom grip LSD's??? ive heard they are true LSD and arent that good???
Old Nov 28, 2005 | 04:56 PM
does anyone know if an ITR LSD will work in a 92 GS-R cable transmission(YS1)????
if so, does it need anything to be done? I read something about using different bearings? what else? details on what exactly needs to be done would be great!
thanks.
Old Nov 28, 2005 | 05:00 PM
nickG's Avatar
search around on g2ic.com yet??
Old Nov 28, 2005 | 07:59 PM
Crx Jimmy's Avatar
yes it can be done, it will fit as long as you have the 4.4 final, you have to do a little clearancing of the cases with a dremel but it will fit, you will want to use the new style bearing not the old 2pc style
Old Nov 28, 2005 | 08:28 PM
Default Re: ITR LSD direct fit into a YS1 (Crx Jimmy)
if i use the 4.4 final, will i still have to do some machining with the dremel?
Old Nov 29, 2005 | 06:15 AM
MoonScryer's Avatar
You have to take some of the webbing support off the inner casing of the YS1 where the LSD will sit.
See here: http://www.outlawatvclub.com/u....html
Thank lococoin for that how-to.
Old Nov 29, 2005 | 01:34 PM
Default Re: (MoonScryer)
any other opinions? is this a fact that the ITR LSD will not fit in my YS1 92 GS-R transmission without some grinding of the inner case???
Old Nov 29, 2005 | 02:06 PM
Kendall's Avatar
Default Re: (92integraVTECgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">is this a fact that the ITR LSD will not fit in my YS1 92 GS-R transmission without some grinding of the inner case???</TD></TR></TABLE>
It is indeed a fact.
yaaj1320
Apr 11, 2007 07:26 AM
boosted94teggy
Apr 25, 2006 01:26 PM
cornholioEK
Sep 30, 2002 06:46 PM
evo
14
Aug 3, 2002 05:53 AM
CivicSiR7
11
Feb 18, 2002 10:10 AM
