Suspension & Brakes Theory, alignment, spring rates....
Rear toe won't spec.
Old Nov 25, 2005 | 07:22 PM
danv's Avatar
Default Rear toe won't spec.
I have a '98 all stock Civic EX(the wife's car). I hit the corner of a curb and knocked the left rear toe out of alignment(total toe is out also). I had it aligned but couldn't get it w/i specs and was maxed out. I changed the struts and had it aligned again; same thing. There is no damage noticable.
I'll be putting new tires on soon and don't want premature wear.
Is there an alignment kit that I can get to correct the toe? Is -.5 deg. enough to cause wear? It's spec'd out for +.08 to +.32. That seems to be out quite a bit.
Any help would be greatly appreciated;
Dan
Old Nov 25, 2005 | 07:40 PM
.RJ's Avatar
.RJ
Default Re: Rear toe won't spec. (danv)
Shocks dont have anything to do with alignment - something is bent, and i'd put money on the trailing arm. they fold up and bend really easy in any sort of curb impact.
Old Feb 16, 2006 | 10:56 AM
CrisEK's Avatar
yep..trailing arm for sure. I bent a trailing arm hitting a curb too.
Old Feb 17, 2006 | 06:53 AM
94rs-turbo's Avatar
they are correct had same problem with my set-up the trailing are will control the amount of toe you have if u are having camber issues them get a rear camber kit
r_arraz
Suspension & Brakes
Nov 28, 2012 12:40 PM
hrdsktr1988
Honda Civic (2006 - 2015)
Jul 19, 2012 05:20 PM
beana
Jan 4, 2010 02:08 PM
RED EK NJ
Suspension & Brakes
Mar 27, 2005 12:58 PM
dng
May 25, 2004 07:29 AM
