Coolant leak coming froma around this area
Old Nov 25, 2005 | 12:17 PM
seeeya04's Avatar
Default Coolant leak coming froma around this area
I have a coolant leak around this area...seems like where the head meets the block
Old Nov 25, 2005 | 12:24 PM
Luserkid's Avatar
Default Re: Coolant leak coming froma around this area (seeeya04)
could be that its actually leaking from the hose? Do you see a trail or anything?
Old Nov 25, 2005 | 12:25 PM
Turbo_y8's Avatar
if its leaking where you say it is, sounds like a head gasket
Old Nov 25, 2005 | 12:26 PM
seeeya04's Avatar
Default Re: Coolant leak coming froma around this area (tuck'd98)
Brand spaanking new hg
And yes there is a trail
Old Nov 25, 2005 | 12:28 PM
Luserkid's Avatar
How long ago did you do the head gasket and how long ago did you notice this?
Also is the trail coming from the hose? If so then just tighten it down more. If by chance its coming from back of the manifold then your going to have to take it off and put it on again.
Old Nov 25, 2005 | 12:29 PM
Turbo_y8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seeeya04 &raquo;</TD></TR><TR><TD CLASS="quote">Brand spaanking new hg
And yes there is a trail</TD></TR></TABLE>
track it, generall will go to the front of the vehicle
Old Nov 25, 2005 | 12:48 PM
seeeya04's Avatar
ill cheak the hose in a few look at it in more detail
Old Dec 6, 2005 | 08:35 AM
dpetro1's Avatar
hey bro any update on this. i also have a small coolant leak coming from that area. it almost seems like its coming from under the dizzy. im thinking maybe its one of the ECT sensors or something. i also have a new HG and i am still getting a small amount of coolant leakage that is running down to the corner of the block above the engine stamp. any ideas guys? thats such a hard area to work in with all those hoses and whats not running around.
Old Dec 6, 2005 | 11:43 AM
ArinX's Avatar
how can that be a headgasket issue? intake manifold gasket would be my guess.
Old Dec 6, 2005 | 11:48 AM
dpetro1's Avatar
Default Re: Coolant leak coming froma around this area (ArinX)
well mine isnt leaking in the same place as his but it kinda makes it look like the hg because the coolant runs toward the front of the motor where the engine stamp is, where you can see the little piece of the hg sticking out. i traced mine back to somewhere under the dizzy , doesnt look like the intake mani but im not positive.
kelviiv
Feb 26, 2008 07:26 PM
crx00
Feb 15, 2006 11:21 AM
EK9 BEEZLER
Apr 18, 2005 09:58 AM
jaxx4k
Oct 14, 2004 12:43 PM
prendi
Aug 22, 2003 02:10 PM
