JDM EF9 B16 shift linkage in a USDM EF will it work?
Old Nov 25, 2005 | 12:12 PM
RuthlessEF-9's Avatar
Default JDM EF9 B16 shift linkage in a USDM EF will it work?
does anyone know if the JDM EF9 B16 linkage will work for a swap? im comparing it to my HASPORT linkage and they look identical and same measurement? I'm pretty sure someone has thought of this instead of cutting an integra one or purchasing a HASPORT linkage.
Old Nov 25, 2005 | 12:22 PM
dr_latino999's Avatar
Default Re: JDM EF9 B16 shift linkage in a USDM EF will it work? (RuthlessEF-9)
I believe it would work saying it was designed for a shifter in spot A in the EF chassis and the B-Series transmission in Spot B.
Old Nov 25, 2005 | 02:02 PM
firme ef8's Avatar
yes it will. i used it and it worked fine.
Old Nov 25, 2005 | 02:42 PM
d357r0y's Avatar
I have ef9 linkage on my car. it's a little short but it works a-ok
Old Nov 25, 2005 | 03:07 PM
.Noah Fecks's Avatar
Default Re: JDM EF9 B16 shift linkage in a USDM EF will it work? (d357r0y)
i was gonna just tell him to go put it on and find out.
Old Nov 25, 2005 | 06:24 PM
EL Vap133's Avatar
Default Re: (xownsx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xownsx &raquo;</TD></TR><TR><TD CLASS="quote">yes it will. i used it and it worked fine.</TD></TR></TABLE>
shortstopNE
Aug 12, 2012 04:30 PM
efjones9
Aug 7, 2009 04:48 PM
rcdohc
Jun 15, 2007 11:10 AM
tealjdmcrx
Welding / Fabrication
Feb 21, 2006 10:41 AM
jdmap1
Mar 9, 2005 08:15 PM
