h22 bearing clearance
Are the h22 main bearings and rob bearings the same clearance as the h23?
H23 specs out of helms
Connecting Rod Bearing Clearance:
Standard(new) 0.021-0.049mm
(0.0008-0.0019in)
service Limit 0.05mm (0.002 in)
Main Bearing Clearance:
Standard(new)
NO. 1,2 0.021-0.045mm
(0.0008-0.0018in)
service Limit 0.050mm (0.0020 in)
No 3 0.025-0.049 mm
(0.0010-0.0019 in)
service Limit 0.054mm (0.0021 in)
No. 4 0.013-0.037 mm
(0.0005-0.0015in)
service limit 0.050 mm (0.0020 in)
NO. 5 0.009-0.033 mm
(0.0004-0.0013 in)
service limit 0.050 (0.0020 IN)
thanks you to anyone that looks in there h22 helms and tells me if the specs are the same or different.
(0.0008-0.0019in)
Standard(new)
(0.0008-0.0018in)
No 3 0.025-0.049 mm
(0.0010-0.0019 in)
(0.0005-0.0015in)
(0.0004-0.0013 in)
thank you so much
oh yea rember a long time ago i asked you about a sh block and a h23 tranny and you said i will need a adapterplate and that you could make me one. i will be needing to do that soon
No problem.
Pirate
*EDIT*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude »</TD></TR><TR><TD CLASS="quote">Connecting Rod Bearing Clearance:
(0.0008-0.0019in)
Standard(new)
(0.0008-0.0018in)
No 3 0.025-0.049 mm
(0.0010-0.0019 in)
(0.0005-0.0015in)
(0.0004-0.0013 in)
service limit 0.050 (0.0020 IN) </TD></TR></TABLE>
from my 1993 Helm manual:
Connecting Rod Bearing Clearance for H23A1 and H22A1:
Standard(new) 0.027-0.055mm
(0.0011-0.0022in)
service Limit 0.06mm (0.0024 in)
Standard(new)
No. 1&2 0.021-0.045mm
(0.0008-0.0018")
service limit 0.050mm (0.0020 in)
No 3 0.025-0.049 mm
(0.0010-0.0019 in)
service limit 0.054mm (0.0021 in)
(0.0005-0.0015in)
No. 5 0.009-0.033 mm
(0.0004-0.0013 in)
Modified by PirateMcFred at 9:47 PM 11/25/2005
Pirate
*EDIT*
(0.0008-0.0019in)
Standard(new)
(0.0008-0.0018in)
No 3 0.025-0.049 mm
(0.0010-0.0019 in)
(0.0005-0.0015in)
(0.0004-0.0013 in)
(0.0011-0.0022in)
Standard(new)
(0.0008-0.0018")
No 3 0.025-0.049 mm
(0.0010-0.0019 in)
(0.0005-0.0015in)
(0.0004-0.0013 in)
nemesis25
Oct 18, 2012 04:09 AM
99blackvti
Nov 12, 2005 09:32 AM
