Wiring Harnesses throughout the different years 88-91
Old Nov 25, 2005 | 11:16 AM
ICeDoUt's Avatar
Default Wiring Harnesses throughout the different years 88-91
What is the difference if any at all?? i do not mean between the models, i mean lets take the SI harness from 88 through 91, supposedly i can't use the 91 harness in the 88 and vice versa. Thats according to information i found while searching. But what is the real difference, why can't i use them?
Take the 88 crx si for example what harnesses would work?
Talking about the engine harness here, nothing else......
Old Nov 25, 2005 | 11:42 AM
jlicrx's Avatar
Default Re: Wiring Harnesses throughout the different years 88-91 (ICeDoUt)
the 88 Si is different from 89-91 Si - it has a square 6 wire connector at the driver's side shock tower, where the 89-91 Si has a round 8 wire connector - the extra 2 wires are for the Fast Idle Control Valve which 88 didn't have
Old Nov 25, 2005 | 12:00 PM
ICeDoUt's Avatar
Default Re: Wiring Harnesses throughout the different years 88-91 (jlicrx)
is it possible to re-wire/splice it and make the other year harnesses work on the 88?
Old Nov 25, 2005 | 12:13 PM
jlicrx's Avatar
yes, you would need to swap a square 6 wire connector onto the engine harness so that it would plug in or swap a round 8 wire connector onto the 88 chassis harness (using only 6 wires) - the wires that match up are: the 4 injector wires - red, brown, yellow, light blue - the injector resistor box, yellow/black and the EACV, blue/yellow - the ones you don't need, which are for Fast Idle Control Valve are dark blue and black/yellow
Old Nov 25, 2005 | 12:19 PM
ICeDoUt's Avatar
cool thanks for the info
ilikericedotcom
Mar 3, 2010 06:43 PM
janz3n
Nov 11, 2008 09:43 AM
mugen_teg
Sep 6, 2006 04:19 PM
soulassasincc
May 11, 2006 06:13 PM
chirp2hrd
10
Sep 12, 2002 10:21 AM
