fuel pump
Old Nov 25, 2005 | 09:52 AM
erubio14's Avatar
Default fuel pump
I went to autozone to get a new fuel pump since i did a swap with b16a3 from d16y7. and the fuel pumps for both motors were both the same serial number from autozone. i asked for an si pump but they said that the only fuel pump they had is for both these motor types. but that can't be true can it?
Old Nov 25, 2005 | 10:28 AM
pro547's Avatar
Default Re: fuel pump (erubio14)
I'm pretty sure that both of the fuel pumps pump pretty much at the same rate. If you would have searched you would have found out that the stock fuel pumps support over 300whp
https://honda-tech.com/zero...41717
EJ8CIVIC
Jul 5, 2015 12:07 PM
VspecSiR
May 17, 2004 04:37 AM
85mm LsVTEC
Dec 22, 2003 10:19 AM
CWBETB
Mar 18, 2003 07:08 AM
