How do you make the OEM foglights come on with parking lights?
How do you make the OEM foglights come on with parking lights? My foglights come on only with headlights, and turn off when i use my highbeams. I was wondering how to make them stay on with parking lights and high beams because the high beams on eg's arent all that great.
Just run the wiring to a switch that you turn on your just tap into the wired for you parking lights, just like you would do with the JDM city lights or sidemarkers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralphie14 »</TD></TR><TR><TD CLASS="quote">Just run the wiring to a switch that you turn on your just tap into the wired for you parking lights, just like you would do with the JDM city lights or sidemarkers.</TD></TR></TABLE>
I think you are trying to say to connect the power wire of the fogs to the power wire of the parking lights. I was wondering this myself, and I would think this should work.
It's kind of like when I hooked up my EDFC, I just hooked the power wire for the EDFC into power wire of the radio, and they both come on when I turn the key to IGN-1.
As far as the high beams are concerned, I am not sure. As far as I know, all vehicles' fog lights turn off when the high beams are turned on.
Hope this helps somewhat. If you need it, I can supply you with which wire you need to tap into on the parking lights for the power, but I need to get ready for work right now.
-Shane
-Shane
I'm guessing it would be ok to tap into the power wire with speaker wire or something right? Which wire is the power wire for the fogs/parking lights?
a friend of mine told me there was a write up on this, i can't seem to find it..can anyone help?
Pretty sure on all Hondas it's red/black, but you have the repair manual so verify it in the back on the elec diagrams.
