B series crank snout outer diameter/crank damper inner diameter?
I searched and much to my surprise/dismay this has not been covered before. I'm in need of some measurements on a B series damper/crank? I just want the the ID of the damper, the size of the keyway or the OD of the crank snout/size of the keyway. I need this info because I want to put an ATI damper on my D16.
22mm and 24mm are the dimensions of D16 cranks. but for some reason I just measured mine and came up with 23mm... It's probably just the measuring equipment.
anyway, thanks for your help!
Hey man--do you want the b-series crank measurement so you can put either a fluidamper or ATI damper on your d-series? I am wondering the same thing--its a good idea.
Yessir. That is my intention to use an ATI damper.
I've heard rumors of people modifying B16 crank pulleys to work on D bangers... but it's questionable info, i want to really get facts.
