Integra Starting Problem (yes i searched)
Old Nov 25, 2005 | 06:14 AM
LSracing94's Avatar
Default Integra Starting Problem (yes i searched)
ok so sometime i go to start my teg and it will crank and turn over fine, but sometime i will turn the key and nothing happens, i know it is not that battery..nor do i think it is the starter because it seems if i jiggle the key around in the ignition that the car will then start to crank...i dont know if this means it is the ignition switch?? can someone clarify what the problem is?? thanks.
Old Nov 25, 2005 | 06:34 AM
pdotjones's Avatar
Default Re: Integra Starting Problem (LSracing94)
LOOSE WIRE POSSIBLY?
Old Nov 25, 2005 | 07:00 AM
KeithsDAteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSracing94 &raquo;</TD></TR><TR><TD CLASS="quote">... i know it is not that battery..nor do i think it is the starter because it seems if i jiggle the key around in the ignition that the car will then start to crank....</TD></TR></TABLE>
Describe your jiggle a little more.
Do you mean trying to crank it numerous times??
Or do you mean wiggle it back and fourth while cranking it??
Old Nov 25, 2005 | 12:49 PM
LSracing94's Avatar
Default Re: Integra Starting Problem (KeithsDAteg)
i wiggle back and forth while key is in cranking position then it starts cranking..
Old Nov 25, 2005 | 06:58 PM
LSracing94's Avatar
bump for help
Old Nov 25, 2005 | 10:12 PM
SJP0tato's Avatar
It sounds like the ignition switch is the most likely candidate. If it does nothing at all until the wiggling in the cranking position it's suspect. If you're able to borrow an ignition switch from a friend (maybe offer to buy them lunch to let you test it for a few minutes) that's the best way to find out.
If you have a helm manual (or you have an online copy of one) it outlines a method to test if it works or not. It involves testing the various leads for continuity I think that might help you diagnose it. The biggest catch is no parts stores I know of will return electrical parts once opened/installed.
You can try removing the ignition switch and check the contacts/terminals inside the plastic casing. Sometimes when they start going bad it will look worn/corroded inside, I've tried cleaning them before but it has never worked for me other than complete replacement.
Good luck!
hope these help:
http://www.we-todd-did-racing....x.jpg
Modified by SJP0tato at 11:40 PM 11/25/2005
Old Nov 25, 2005 | 10:23 PM
phateless's Avatar
sounds like when the starter went out in my accord. if i tried to turn the key a bunch more times it would eventually start to crank. when you jiggle the key, does it crank normally or start to crank reluctantly? by the way, if you pull your starter, most parts stores will test it for you for free.
EFS463
Aug 14, 2013 05:10 PM
dan.
May 19, 2013 02:10 PM
ck123
Jun 16, 2006 09:58 PM
gwakie
Feb 10, 2005 05:12 AM
Bklyn TSi
Sep 24, 2001 11:39 PM
