Suspension & Brakes Theory, alignment, spring rates....
ITR Suspension Into 2000 Civic SI
Old Nov 25, 2005 | 04:05 AM
EleanoR's Avatar
Default ITR Suspension Into 2000 Civic SI
I have in my garage the stock Type R spring/shock assembly for all 4 corners (both front and rear for you slow guys). I don't have any of the other suspension pieces left over from installing on my hatch.
Anyhow, would these assemblies fit my brother's 2000 Civic Si model? It looks like the rear assemblies are different in the way that they mount to the lower control arm. Would getting ITR control arms be the difference and would they fit?
What about the fronts? Does the stock fork accomodate the Type R strut/spring assembly with no problem? Discuss please........
Old Nov 25, 2005 | 03:13 PM
alwaysoverkill's Avatar
i believe the fronts will fit but not the rears. Add ITR rear lower control arm and the rears should then fit, i'm not sure about the rear though.
go for the 22mm rear sway bar (With Beaks or ASR reinforcement kit) and it'll be a fair difference, although the suspension will still feel alittle soft compared to aftermarket, but should feel better then stock.
Old Nov 25, 2005 | 10:18 PM
StylishDOHC's Avatar
Default Re: (alwaysoverkill)
ITR rear LCA's will not fit 96-00 Civic's.The fronts will fit just fine however.
Old Nov 26, 2005 | 07:24 AM
EleanoR's Avatar
Default Re: (SylishDOHC)
ok so the fronts work. on the rears, what control arms would I need to get in order for the rear suspension to bolt right in?
Old Nov 26, 2005 | 06:47 PM
cruizinmax's Avatar
I'm not sure if anything would work to make the rears fit. I don't think the CTR has different control arms than the standard SI.
Old Nov 27, 2005 | 06:36 AM
EleanoR's Avatar
Default Re: (cruizinmax)
bump for someone that knows for sure because i am willing to get different control arms that would work if that's what makes them fit properly.
Old Nov 27, 2005 | 08:17 AM
hayabusa160's Avatar
Default Re: (EleanoR)
theres no rear lca that will make them work on a ek.
Old Nov 27, 2005 | 03:04 PM
EleanoR's Avatar
Default Re: ITR Suspension Into 2000 Civic SI (EleanoR)
can anyone confirm this that no control arm can be bought either OEM or aftermarket that would allow the rear suspension assembly (spring and shock) to work?
Old Nov 27, 2005 | 10:55 PM
chrisw85's Avatar
Default Re: (hayabusa160)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 &raquo;</TD></TR><TR><TD CLASS="quote">theres no rear lca that will make them work on a ek.
confirmed
The DC2/DC2R/EG rear LCAs are different lengths than the EK rear LCAs (longer/shorter, i forget which). This makes the suspension mount points line up differently.
The DC2/DC2R/EG themselves are all the same lengths.
Old Nov 28, 2005 | 06:24 AM
EleanoR's Avatar
Default Re: (chrisw85)
thanks so much. now the next question. is there a control arm that i can buy aftermarket that would allow me to use the rear suspension from a Type R into this 2000 Civic Si? I would think that someone made it somewhere along the line.
Old Nov 28, 2005 | 07:24 AM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EleanoR &raquo;</TD></TR><TR><TD CLASS="quote">thanks so much. now the next question. is there a control arm that i can buy aftermarket that would allow me to use the rear suspension from a Type R into this 2000 Civic Si? I would think that someone made it somewhere along the line.</TD></TR></TABLE>
As far as I know there is no aftermarket LCA that is like the ITR lca.
B_Swapped93
Sep 25, 2013 09:32 AM
bryantran84
Nov 19, 2011 10:23 AM
sicksiguy
14
Dec 12, 2006 05:50 PM
awdriscol4
Suspension & Brakes
21
Mar 11, 2005 10:34 AM
RoAnSa
12
Nov 24, 2002 07:54 AM
