help need ur guys honda experties
i have a 91 civic hatch back, converted to obd1..but still using the stock intake manifold...wanting to convert to a 99 intake manifold.....running single cam turbo.....wondering what i need to keep on the 99 intake manifold and what sensors i dont need..like the air temp..and so on...is this possible?? also got a 95 gs-r throttle body..please help any suggestions would be great help..
If you are using the Y8 manifold, you need the one from a 5spd. It has the cool black sensor on the back. You will also have to drill a hole and rig up another sensor in the back.....I believe it's the IAT?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Animal »</TD></TR><TR><TD CLASS="quote">If you are using the Y8 manifold, you need the one from a 5spd. It has the cool black sensor on the back. You will also have to drill a hole and rig up another sensor in the back.....I believe it's the IAT?</TD></TR></TABLE>
Y8 Manifold - Preferences
96-98 and 5 Speed
99-00 Have vacuum ports up the ying yang, and the auto has differences that are just annoying.
IAT Can be mounted on the intake tract
Port match manifold to throttle body.
96-98 and 5 Speed
hondaEg_808
May 12, 2008 01:29 PM
