!!! Clutch problem: master/slave cylinder failure
Old Nov 24, 2005 | 05:08 PM
Schurke's Avatar
Default !!! Clutch problem: master/slave cylinder failure
Ok, so I have a master or slave cylinder failure, I don't know which. We'll start with the basics, when I press my clutch it floors down without any resistance whatsoever. I didn't check into anything as of yet, because it's late, dark, cold, and snowing. What should I look for in the cylinders for problems? How much on average do new cylinders cost (both, don't want to risk replacing one and then finding out the other was bad.)? I'm not certain if this is the master/slave cylinders, so any other suggestions are welcome. The transmission in question is obviously hydraulic and is in my 1999 Honda CRV (AWD). Thank you in advance.
p4v:
Old Nov 24, 2005 | 05:16 PM
Schurke's Avatar
Default Re: !!! Clutch problem: master/slave cylinder failure (Schurke)
Ooops, wrong forum. But if you can help me please do.
https://honda-tech.com/zerothread?id=1444542
phookie
Jan 27, 2009 08:25 PM
tato1983
Dec 11, 2007 05:52 PM
siregcivic
Oct 16, 2005 07:55 PM
