What is the difference between dry suspension setup and rain suspension for RRacing
how roadrace racer tune differently their suspension setup for rain compare to dry circuit?
I imagine they would only have to change their driving techniques, and perhaps tires. Just a guess though.
I've seen/heard people unhooking sway bars. Other than that, tire pressures and/or compounds.
Soften everything up if you can, springs, shocks, swaybars and drop 2-3 psi from the tires. If you cant change anything, just change tire pressure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">Soften everything up if you can, springs, shocks, swaybars and drop 2-3 psi from the tires. If you cant change anything, just change tire pressure
this assumes that you were optimally stiff for the dry to begin with. most cars i've seen are plenty soft enough in roll even in the wet. a simple softening of the shocks and tire pressures to increase how forgiving the car is will suffice. cars with a gross imbalance of roll stiffness fr vs. rr will be affected more by changes in grip then a more balanced setup and will need to take more drastic measures to get a driveable package in the wet. yet another reason to make sure you only barely lift that inside rear tire.
nate
</TD></TR></TABLE>this assumes that you were optimally stiff for the dry to begin with. most cars i've seen are plenty soft enough in roll even in the wet. a simple softening of the shocks and tire pressures to increase how forgiving the car is will suffice. cars with a gross imbalance of roll stiffness fr vs. rr will be affected more by changes in grip then a more balanced setup and will need to take more drastic measures to get a driveable package in the wet. yet another reason to make sure you only barely lift that inside rear tire.
nate
thegooddoctorceretti
Jun 23, 2007 12:05 PM
civic_tko
10
Nov 4, 2004 02:29 PM
civicturbo
12
Dec 13, 2001 09:17 PM
