Gas Fumes coming out of shirt ram intake.
Old Nov 24, 2005 | 03:33 PM
hprelude93's Avatar
Default Gas Fumes coming out of shirt ram intake.
What could this mean? USDM H23 motor.
Old Nov 24, 2005 | 03:51 PM
BB6racer's Avatar
when i put my head back on, i had some smoke coming from the valve cover breathers. some coolant had gotten into the oil passages and was burning off as white smoke. i don't know if that is your case though.
also, very low oil makes smoke. i'm not sure why, but it happened when my motor leaked (right before the head came off).
what have you done to your car lately? tune up, add oil, change spark plugs...
Old Nov 24, 2005 | 04:31 PM
dblock2x's Avatar
if smoke is coming out of your intake/im, you need to check the timing of you motor. did this happen all of a sudden or was it a result of modification
Old Nov 24, 2005 | 05:44 PM
hprelude93's Avatar
Default Re: (.cooper.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .cooper. &raquo;</TD></TR><TR><TD CLASS="quote">if smoke is coming out of your intake/im, you need to check the timing of you motor. did this happen all of a sudden or was it a result of modification</TD></TR></TABLE>
It happened when my crank pulley came loose causing the belts to pop off. got the pulley abck on and the belts back on...but the motor is struggling to turn over..and wont start. and i noticed that i had a very small amount of smoke coming out of the intake cone...and it smells strongly of fuel!
Old Nov 24, 2005 | 07:33 PM
SnlpeR's Avatar
a motor wont start with 0 compression
have you checked if youre getting compression like i said in your other post?
and if your valves are bent....the air could be escaping thru youre intake
Old Nov 24, 2005 | 07:37 PM
SnlpeR's Avatar
heres an h23a head (mine) when the crank pulley came off
timing belt and tensioner belt were still ON
i should have checked if the timing was still perfect before i took the belts out tho
but this was the result...its weird how it happend even with the belts still in tact
Old Nov 24, 2005 | 08:45 PM
hprelude93's Avatar
Default Re: (SnlpeR)
How do i check my compression???? And what exactly am i looking at in that picture?
Old Nov 25, 2005 | 05:22 AM
SnlpeR's Avatar
16 bent valves
Old Nov 25, 2005 | 07:10 AM
hprelude93's Avatar
well..im going to start tearing stuff apart today. You told me to check my compression.....how do i do that?
Old Nov 25, 2005 | 09:03 AM
SteveoBA8's Avatar
Default Re: (hprelude93)
go buy a compression gauge.i dont feel like typing the steps riht now
Old Nov 25, 2005 | 10:51 AM
OEM_ASSASSIN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnlpeR &raquo;</TD></TR><TR><TD CLASS="quote">heres an h23a head (mine) when the crank pulley came off
damn
Old Nov 25, 2005 | 11:38 AM
PirateMcFred's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnlpeR &raquo;</TD></TR><TR><TD CLASS="quote">16 bent valves</TD></TR></TABLE>
Looks like time for a refresh/mill/valves/V-Job/P&P and some big cams to me...
Pirate
kixcrx
19
Mar 29, 2007 07:02 PM
Tee Jay
Mar 16, 2006 09:29 AM
98-0688
Oct 9, 2004 08:50 AM
wizzards581
Oct 24, 2003 06:41 AM
