Honda S2000 Honda S2000
I was bored, so I'm trying to make a radiator plate for my setup.
Old Nov 24, 2005 | 10:55 AM
Mr. Projekt's Avatar
* B A N N E D *
Default I was bored, so I'm trying to make a radiator plate for my setup.
Yea, its supposed to go with that thing. I'm actually working on it right now, so the progress will be kinda slow.
Old Nov 24, 2005 | 10:57 AM
* B A N N E D *
Default Re: I was bored, so I'm trying to make a radiator plate for my setup. (Slideways2000)
I'm working with this 12"x24" piece of infused twill weave CF, honeycomb backed.
Old Nov 24, 2005 | 11:59 AM
Mr.E.G.'s Avatar
good effort. a lot of people are too afraid to do homemade stuff on their s2000's because they think they drive ferraris and therefore homemade parts are beneath them.
good to see you are still keeping it real
keep us updated on your progress
Old Nov 24, 2005 | 12:01 PM
Mr.E.G.'s Avatar
Default Re: I was bored, so I'm trying to make a radiator plate for my setup. (Mr.E.G.)
why is the engine out? are you plannig something big? or did it blow up?
Old Nov 24, 2005 | 12:14 PM
papa5murf's Avatar
where did you get the piece of carbon fiber?
Old Nov 24, 2005 | 12:24 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.E.G. &raquo;</TD></TR><TR><TD CLASS="quote">why is the engine out? are you plannig something big? or did it blow up?</TD></TR></TABLE>
Motor is out because a new seamwelded crossmember and radiator support was in order. While it was out I swapped the drivetrain full of Royal Purple, added a Mugen thermostat and fanswitch. It was also time to do some custom intake ducting, and I think I've just figured out a way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">where did you get the piece of carbon fiber?</TD></TR></TABLE>
Check the sig man. I pawn this ish.
Modified by Slideways2000 at 6:18 PM 11/24/2005
Old Nov 24, 2005 | 12:25 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slideways2000 &raquo;</TD></TR><TR><TD CLASS="quote">
See that A/C condenser? There will be no lines attached to it, there isnt even an A/C compressor. =D Its a dummy y0!
Old Nov 24, 2005 | 12:43 PM
Mr.E.G.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slideways2000 &raquo;</TD></TR><TR><TD CLASS="quote"> I pawn this ish.</TD></TR></TABLE>
so you make the parts your self?
if so, i bow down. i havent the slightest idea how that is done. if i made you a fiber glass mold, could you make peices for me in carbon fiber or frp?
if so we need to talk.
Old Nov 24, 2005 | 01:56 PM
* B A N N E D *
We need to talk.
Old Nov 24, 2005 | 04:51 PM
* B A N N E D *
So here's where I'm at. This pic was taken a little before I was done, while there was still light out. Managed to finish the edges, fit it to the radiator, and made holes to attach it to the front support and attached a radiator stay atop that as well. Will show better pics tomorrow; I didn't have any AA batteries for my digicam today.
Old Nov 24, 2005 | 04:53 PM
* B A N N E D *
That intake tube you see to the right was the initial intended placement of the air filter, behind the driverside headlight. It will now be placed next to the headlight, just forward of the radiator, hence the plate being shorter on that side. This is all done with an off-the-shelf AEM CAI.
Modified by Slideways2000 at 6:16 PM 11/24/2005
Old Nov 25, 2005 | 09:55 AM
dkim48's Avatar
looks nice...good luck on the project. are you going to be filling in all the empty spots though? it would seem like a wasted effort if the sides weren't filled in.
Old Nov 25, 2005 | 11:24 AM
SuzukaBlueAP2's Avatar
Default Re: I was bored, so I'm trying to make a radiator plate for my setup. (dkim48)
yeah, make sure it is pretty well sealed. As well as make sure that any any air you want directed to your intake is done also.
Old Nov 25, 2005 | 11:59 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkim48 &raquo;</TD></TR><TR><TD CLASS="quote">looks nice...good luck on the project. are you going to be filling in all the empty spots though? it would seem like a wasted effort if the sides weren't filled in.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">^^
yeah, make sure it is pretty well sealed. As well as make sure that any any air you want directed to your intake is done also. </TD></TR></TABLE>
CF baffles will be made as attachment to the actual top plate. I do want to route airflow to the radiator and intake only, and when the IC comes in I can make due for that also. Thanks for the comments.
Old Nov 26, 2005 | 01:48 AM
jimbonuttz's Avatar
wsup myspace and fellow s2k buddy!
s2k jimbo
Old Nov 26, 2005 | 04:28 AM
solsurvivor's Avatar
Default Re: I was bored, so I'm trying to make a radiator plate for my setup. (jimbonuttz)
slide:
just to be an ***: what is the purpose of this, or let me refrase: what are your goals with this.
The cooling surface of the radiator is identical, hence no gains to be reached here. Only thing your doing here is diverting the air diagonally against a tilted surface as opposed to the fact that it otherwise hits a full flat surface. if you do not fill the sides of the panel, I bet you lose more then you gain. This setup is functional if you using a V setup for your rad/intercooler. the original setup is pretty much effective as hell, gains only to be reached by replacing the stock rad with a thicker core......
it nevertheless looks cool......
Old Nov 26, 2005 | 09:10 AM
* B A N N E D *
Default Re: I was bored, so I'm trying to make a radiator plate for my setup. (solsurvivor)
There will be an intercooler there. I'm just thinking ahead.
For now the car will be N/A, hence the funky intake. The intercooler will actually replace that plate, then I'd have to make side shrouds.
OUT_OF_ORDER_DB7
Northern California (Sales)
Oct 4, 2007 07:12 AM
Mr.DC2TurBo
Jan 17, 2005 05:48 PM
Mr.DC2TurBo
Aug 5, 2004 05:43 PM
4bidden
Dec 17, 2003 12:11 PM
Miracle_X_Bar
Honda S2000
10
Oct 16, 2003 06:04 PM
