It still wont start!!!!!!!!!
Alright, i need a couple solutions here, im having trouble getting my rex(91 Si) started. When i crank it it wont hesitate to turn on at all. Just cranks. Spark is fine, just replaced plugs and wires are brand new. Slapped on a new dizzy. Timings On. All grounds secure. Fuel gauge reads accurate. Fuel Pump comes on when keys turned on. Bled radiator coolant. I checked the eacv for any clogging and it was fine but whats crazy is when i put it back on it wanted to turn over. But it didnt. Now i have ran out of things to check. Any suggestions. Any help needed A.S.A.P!!!!!
Thanx guys.
Thanx guys.
maybe a ground? any possibility of corrosion in the battery cable? loosen the fuel connection at the rail and turn the key to the on position. fuel should come out under pressure. if not then the filter may be clogged. any codes?
OK, you are sure you have spark in every cylinder right? That takes out Main relay and just about anything in the dizzy. If you have spark it's either timing or fuel. Are you sure the cylinders are getting fuel? Just because you pump turn on doesn't mean you are getting anything. Pull the plugs and check to see if they are wet. If you have spark and fuel I would check to see if timing is off for some reason.
I have see the dizzy bearings go bad and pull stuff like this. Make sure you distributor is in good shape. Pull it off and spin it. Make sure it is not binding and it has no play.
Alright, which hose exactly. Cause if it was the filter my fuel Pressure gauge wouldnt Mark correct? And no Codes? And i failed to mention that it would also sit at a rough idle at start up. Maybe this led to the problem.......?
JDM Freakk
Jun 21, 2011 05:36 PM
PinkMaggit
16
Nov 28, 2008 05:25 PM
