CLUTCH PROBLEM I HAVE SEARCHED
Here is my problem. All of sudden my clutch pedal feels softer. And then starts to stick and then not spring back at all and sticks to the floor board. The weird part. The clutch has fluid and I HAVE BLEED the line once. The clutch pedal, when I pump it after awhile it will go back to normal condition and then after I drive without using it, it will go back to falling to the floor board. Another Thing, if this helps, when I hold the clutch pedal, like at a light, for a long period of time it does stay engaged.
1. Pedal falls to floor board
2. I have bled the line ONCE
3. Pedal will lose pressure over time
4. Pumping pedal will bring pedal back to life and work perfectly if I use it regularly.
5. Over time if not used, like driving on the freeway, ill lose pressure again.
6. Pedal does not lose pressure, even if I hold it down for along time, like at a light.
HELP! Whats my problem? Sucks I can not shift when I have no pressure.
Another thing when i bled the line it worked for about a week
I 2nd that, mine went during the summer. Mine worked most of the time but replacing it made the pedal so much firmer. It's easy to replace, just be sure to bleed and flush the line at the slave cylinder bleeder.
RTW DC2R
Jun 23, 2006 07:42 AM
