if compression test comes out low, how do i bump it up?
Old Nov 23, 2005 | 08:42 PM
GSRVTEC1's Avatar
Default if compression test comes out low, how do i bump it up?
Old Nov 23, 2005 | 08:48 PM
Code Blue's Avatar
Default Re: if compression test comes out low, how do i bump it up? (GSRVTEC1)
you can't "bump" it up..
your compression test is low because of worn components / headgasket problems.
your thinking of compression ratio of the engine, which is an entirely different thing.
Old Nov 23, 2005 | 09:14 PM
tnord's Avatar
Default Re: if compression test comes out low, how do i bump it up? (Code Blue)
do a leakdown, figure out just what is causing the low compression, and rebuild that part of the engine.
Old Nov 23, 2005 | 09:32 PM
Dogginator's Avatar
Daisy... Daisy...
You can try adjusting your valves first. If they are too tight, the effective compression will be lowered.
88 civic
Apr 5, 2009 03:21 PM
Spectrum24x
Jan 15, 2006 05:08 PM
Curtisbeef
Jul 5, 2005 10:40 AM
self_made
Jun 19, 2005 12:36 PM
